speed reducer
speed reducer
I want to turn bowls of larger diameter. I have a Mark V. I have seen the speed reducer in accessories, but I need to if any one have used one and what success they have had.
I have one and have used it. It does what it is advertised to do and that is a speed reduction of 10:1. I have also used it to power the bandsaw. As far as turning goes, I removed the speed reducer once I got the large blank round. Even with the reducer, you still want to rough the blank between centers.
Rob in San Diego
paulmcohen
mrsawdust wrote:I want to turn bowls of larger diameter. I have a Mark V. I have seen the speed reducer in accessories, but I need to if any one have used one and what success they have had.
I have used it to turn large logs that were not close to round. I just sold mine when I got the PowerPro since it goes even slower.
When I sold it, the person who purchased it know a lot more than I did about and said mine had some manufacturing defects from Shopsmith (wrong belts and some other issues) but it did not affect my usage.
So warning if you purchase one secondhand make sure you check out the insides.
Paul Cohen
Beaverton, OR
Beaverton, OR
- cincinnati
paulmcohen
[/quote][/font][/size]wa2crk wrote:Paulmcohen]
I never had a probelms with it either but the person who purchased it thought I had modified it. He said the belts used were of a different type then specificed in the manual.
What he said exactly was
[font=Arial","sans-serif][quote="Paulmcohen"]Checking the interior through the inspection holes, I noted that the output drive belt was misaligned on the sheaves, creating significant wear on the belt and housing. When I separated the unit, I found that previous belt tension adjustments, made to compensate for the misaligned belt, had offset the idler sheave to the point that it rubbed on the housing, creating serious abrasion on the sheave and housing. The unit also has the wrongpoly-v belts: it has 2 headstock drive belts (#504170), as opposed to the matched set (#515988) specified in the manual.
As I explained this is how I received the unit directly from Shopsmith and I never had issues using it. I guess he was able to adjust the unit and was happy, I don't believe it was a price issue as the subject never came up.
Paul Cohen
Beaverton, OR
Beaverton, OR
That is interesting
I just picked up a used one from a guy that his dad bought. The mounting bracket was still stapled and in the bag. The belts don't show any sign of wear. I don't think the dad ever used it. I set it up according to the manuel, but there is a 1/64 in of wobble in it. Maybe that is normal. I have noticed that one belt does feel a little tight. I am going to check the numbers. make sure they are the right ones.
Thanks for the information
Sunset22
Sunset22
The next SPT I want to buy is a speed reducer. Just missed the sale they had last year and have been waiting for another. Think they are priced a bit high, but willing to go that route if in sale.
I want to use it with my PowerPro for bandsawing and maybe to turn large items.
Think the speed reducer will put an end to the bucking/slamming that the PowerPro does with the bandsaw?????
