Long-time lurker and first time poster.
I've been enjoying my shopsmith Mk 5 since I got it early winter, and am slowly beginning to expand my capabilities with it. I have the potential for a really good deal on a really good 8" dado set, and I'm wondering how well it will or won't work on my SS. Is the 8" dado set simply too big for the SS motor, and one that I should stay away from?
Thanks in advance for any assistance and advice!
John
8" dado set
- Bronze Member
I don't know which dado set you are looking at, but I have used an 8 inch stacked dado on my Mark V and it worked fine. Generally, you only buy the 8 inch set for when you need the depth of cut. In most cases a 6 inch set will handle most jobs.
That being said, if I was getting a great price on a great dado set, I would probably buy it. I always have the ability to dial the speed down to increase the torque at the arbor.
Rob in San Diego
jschmitz1949 wrote:Long-time lurker and first time poster.
John
8" dado blades work great, you just need to remember two things.
- Don't raise the blade so high it cuts into the dado insert.
- If you don't have a PowerPro give the motor enough time to reach full speed before you start the cut.
Paul Cohen
Beaverton, OR
Beaverton, OR
Question is, which size motor do you have? If 1 1/8hp, "OK". If 3/4hp, probably not! Width and depth of cut are the clincher!
Yes, the feed rate always has some effect and I believe that many of use experience the bad effects of feeding too fast without recognizing the root cause.
Slow down - I don't know of a single wood working process that is adversely effected by being done too slow.
