shopsmith sandpapers circa 1981
Who remembers this stuff?
[ATTACH]14335[/ATTACH]
mountainbreeze
Post by mountainbreeze »
That looks like sheetrock sanding screen. So how do you get the SS up to the wall? :D
mountainbreeze wrote:That looks like sheetrock sanding screen. So how do you get the SS up to the wall? :D
I'm having trouble remembering back that far, I think you just pulled the head stock off the tubes and got up on a step ladder, making sure you were set no higher then D then got to work, you were to the 2 x4's in seconds as I recall not that you could see them for the dust. The real test was working on the ceiling....
anmius
Post by anmius »
Sanding the ceiling is easy. Just use the set-up in this picture and exchange the drill chuck for the sanding disk with the sanding screens.
drill up.jpg (61.64 KiB) Viewed 1311 times
Abraham Lincoln
jcraigie
Post by jcraigie »
I believe that could also be called a 12" drill disc:rolleyes:
1984 Mark V 500 and an early 1954 greenie. jointer, belt sander, bandsaw, jigsaw, planner.
Jeff
djmartins
Post by djmartins »
anmius wrote:Sanding the ceiling is easy. Just use the set-up in this picture and exchange the drill chuck for the sanding disk with the sanding screens.
Hmmmm...I think I need a Mark VII!
