Found Treasure!
Shop_Smith_Poppi
Found Treasure!
Post by Shop_Smith_Poppi »
ok guys I just found this is some boxes in my trailer. did not know i stiill had it. Guess the thieves who took my first SS a Mark VII were not as through as they should have been.
well I dont have the cam picture but it is in perfect condition as far as I can see will post a pic of it soon.
"Jerry! how many times do I have to tell you! Lick that knife before you put it back in the butter!" ..... Jerry Clower's Mother.
Interesting 'gallery'.
Do be careful as Hans is watching.;)
[ATTACH]14372[/ATTACH]
FWIW A 10" sanding disk is Mark VII vintage. The back side is 'tapered' The 6" disk is a lathe face plate. The 12" sanding disk will fit in a 505/510/520 table only(They all work just off the table left edge). The table slot inserts are saw blade, a wider dado blade insert and a wide/short molder insert.
Did you make the 'tube chuck' from a chemistry lab rubber cork?
I DO like the black/gold.
BTW The tailstock bracket has a machined slide surface for the extension table mounting bracket. Would be best is those mating surfaces were not painted.
Hans is watching.jpg (226.84 KiB) Viewed 1783 times
Shop_Smith_Poppi
JPG Please explain what you are rattling on about I am quite lost here?
Shop_Smith_Poppi wrote:JPG Please explain what you are rattling on about I am quite lost here?
Thatdarndog / 212, 214, 217, . . . .
Shop_Smith_Poppi
OH my photo gallery ok.
So my Mark VII came with a lot of stuff. Most of which got stolen with it. Pictuers 197 to 223 are what I had from my MarK VII. I still have some but not sure what exactly. will be going through and making an inventory soon.
