Serial number and parts ordering
oscarthefuzz
Serial numbers are confusing me.. I have been through lots of posts on this forum trying to figure out what year the Shopsmith I have is but my serial number does not seem to tally.
I have a green shopsmith with serial number 288123. I suspect it's from 1987 as there is documentation with it giving show prices from Missisauga in that year. It does not have a red toggle switch so I think it's a 500 but maybe it's a 510.
Can someone put me out of my misery I am going blind from reading posts on the computer and apologies if this was covered somewhere else but I just cannot find any serial number corresponding to this on the lists...
thanks in advance
thanks in advance
A photo of your machine would be helpful.
The tables define whether you have a 500 vs a 510. Here's a good link showing the different tables with the older 500, the 505, the 510 and 520 with dimensions.
http://www.shopsmith.com/ownersite/M..._4-28-08r2.pdf
Peter
oscarthefuzz wrote:Serial numbers are confusing me.. I have been through lots of posts on this forum trying to figure out what year the Shopsmith I have is but my serial number does not seem to tally.
thanks in advance
If it has original green paint, it is a 1955 greenie. It is a gilmer drive(unless it has been updated). The quill is part of the gilmer parts mix.
http://www.shopsmith.com/ownersite/serialnumber.htm
Your machine might be a bit older than you are thinking. Click on the following link and scroll to the bottom of the page where you will find a table that shows the manufacturing dates. Chart indicates Dec 1954 or Jan 1955.
http://www.shopsmith.com/ownersite/faq/markv.htm
I went looking for some of the older documents but I can not locate them on the web site. I suspect that 500 documentation is being pulled since a lot of the support for the older equipment is being discontinued. That will be, IMHO, a real shame if Shopsmith has done that. I hope I am wrong.
The following is some documentation that makes me suspect they are pulling the 500 data. The older document also depicted the 500.
http://www.shopsmith.com/markvsite/specifications_3.htm
oscarthefuzz
oscarthefuzz
Actually while I am here and you're being so helpful... the table for the saw won't go in any further than it shows in the second picture, doesn't seem to quite catch the notches on the post and gets quite stuck. Was considering gettin a file to the end so it would slip in a bit further and then catch the notches ... what do ye think? It works fine when the tool rest for the lathe is in there and goes up and down no problem ..
thanks again for the help.
oscarthefuzz wrote:Was considering gettin a file to the end so it would slip in a bit further and then catch the notches ... what do ye think?
I don't think ya outta do that just yet. Have ya cleaned up the table legs and the hole they fit in. Then have ya waxed both?
Although the paint is not OEM, it appears to be a 'greenie'.
1) Since it appears to be a mix of different vintage parts nailing down the bate of birth is doubtful.
2) Although the sn indicates 1955, the belt cover is from an earlier vintage(A headstock).
3) Not absolutely clear from the pix, but the headstock appears it may be a B headstock. A closer look indicates it is an A headstock as well.
4) The tail stock looks(again not absolutely clear in the pix) like it may be a Mark VII vintage.
So you probably have a mix of versions(not bad, just adds to the confusion).
Re the table: Does the lathe tool rest fit 'fine' in the rear carriage hole?
The rack teeth on the table posts engage pinion gears in the carriage. It may be necessary to wiggle the table/posts to help align the racks to the gears. Do not force them. Determine why they are 'jamming' before trying any 'alterations'.
oscarthefuzz
[/IMG]
