I need to get a new connector tube (one of mine is bent).
I was going to order one for $11.45 (#514439) and then I saw that I can get a pair of 5ft connector tubes for $48.54 (#521942).
Does anyone have any input on the longer tubes vs. the shorter ones. I'm thinking that one 5ft tube will be more solid/stable than two short ones. Am I correct on this?
Connector Tube Question
- jcraigie
1984 Mark V 500 and an early 1954 greenie. jointer, belt sander, bandsaw, jigsaw, planner.
Jeff
Jeff
This is one of those situations where any answer is correct.jcraigie wrote:I need to get a new connector tube (one of mine is bent).
I have both long and short connector tubes and I use both types (lengths) regularly. In fact, I have more than two different lengths. I purchased 5' tubes that got bent. I cut the bent tubes into a number of shorter pieces and they all get used. Each setup presents its own set of requirements. I also purchased another set of 5' tubes.
The 5' tubes tend to be a nuisance if used in a setup that involves the main table and then it needs to be raised or lowered. Just about everything must be disconnected before the table height can be changed.
I turned some inserts (let's call them connector tube connectors) that allow me to have a long tube that can be broken into two pieces and then put back together.
I have an extra set of every configuration of connector tubes I could find. Once when looking at a used 510 I found a box containing several miscellaneous tubes and parts some weren't even original Shopsmith. I frequently find that the odd sized tubes and some connectors that I have often wondered origin of extremely handy. Hey a couple of them remind me of connectors from a convertible top I once had on a boat. Dusty is right on target. If one considers the Shopsmith tools are all part of a fantastic unending collection of useable jigs, then the possible uses of connector tubes is vital. Yes I agree Dusty is right on target as always. Fjimp
F. Jim Parks
Lakewood, Colorado:)
michaeltoc
I purchased a pair of 6' tubes from onlinemetals.com for $27.30. They may not be as shiny and pretty as the SS tubes, but the price is right. I cleaned them up with acetone to remove the oil and markings then waxed them.
https://www.onlinemetals.com/merchant.c ... 775&step=4
Michael
Thanks for posting this. This appears to be a very good source for special tube requirements. I may quit cutting up 5' tubes.michaeltoc wrote:I purchased a pair of 6' tubes from onlinemetals.com for $27.30. They may not be as shiny and pretty as the SS tubes, but the price is right. I cleaned them up with acetone to remove the oil and markings then waxed them.
https://www.onlinemetals.com/merchant.cfm?pid=7775&step=4
Here's another source for tubing: http://www.speedymetals.com/s-204-round-tube.aspx?pagenum=3
It is on my to-do list to stop by my local pipe and iron supply and see if the tubing they sell is straight and true enough to use.
Bud F.
