Chinese Drill Bit Drills Square Holes
gr8mesquite
Check this out, you'll be amazed:
http://www.liveleak.com/view?i=78a_1317942353
Is this Photoshop-ed, or real? The mortise of the future?
Jerome
Jerome
Actually this tells it better than slow motion.
[ATTACH]14511[/ATTACH]
Notice the center of the triangle is rotating off center and the corners opposite the cutting corner ride the side of the square.
Gotta wonder how hole gets started.
Certainly not a 'drill bit' in the traditional sense, but it does appear to 'make' holes!
Shaper comes to mind as a descriptor!(in the metal working sense like a ram shaper that follows a square path)
Slight rounding at the 'corners'.
- square drill.jpg (158.55 KiB) Viewed 4283 times
paulmcohen
JPG40504 wrote: Gotta wonder how hole gets started.![]()
If you look at the video, it starts with a round hole.
Paul Cohen
Beaverton, OR
Beaverton, OR
The video shows a round hole, but I believe that is to make less material removal necessary when making the square hole.paulmcohen wrote:If you look at the video, it starts with a round hole.
There is nothing that I see that registers over that hole(as part of the bit).
I have to conclude that the hole does not determine the location of the square hole, but the positioning of the bit is all that determines that.
That leads me to believe the 'bit' merely starts its wiggle dance as it contacts the material being 'drilled'. The triangular cutter cannot reach outside the square sides.
paulmcohen
JPG40504 wrote:The video shows a round hole, but I believe that is to make less material removal necessary when making the square hole.
I did not mean to say the round hole was used for alignment, the machine looks like some kind of CNC machine so registration is done by the X-Y position mechanism.
Paul Cohen
Beaverton, OR
Beaverton, OR
I believe the round hole is there (and has to be there) because the tool is not capable of cutting in the center, which is not uncommon in certain metal working applications.
www.wirewerkes.com
Hiding in a Joshua Tree.
