AC motor controller
AC motor controller
Is there such an animal for my GE 1/2 hp AC capacitor start 7 amp motor?
Thanks guys.
Thanks guys.
Gene
Gene Howe wrote:Is there such an animal for my GE 1/2 hp AC capacitor start 7 amp motor?
Thanks guys.
Depends upon what you mean by 'controller'. If you are referring to a start relay, yes. It takes the place of the start switch and disconnects the start capacitor once up to speed.
And what pray tell is this motor driving? A Model 10?
Since an ac induction motor is designed to run at a specific load/speed range, any speed control must be done mechanically. A DC(or universal) motor is a more likely candidate.Gene Howe wrote:Thanks for your replies.
I should have titled the question "SPEED CONTROL DEVICE".
It will power a homemade drum sander.
Gene Howe wrote:Thanks JPG.
Gonna hafta use pulleys to slow it, I guess. When I was given this tread mill, I thought it had a DC motor.![]()
Oh well.
Question is, do you want to make it adjustable while using, or just to set the speed initially.
I think a ss motor with sheaves is a good variable speed power source. Increasing tension(by way of an idler pulley etc.) will decrease the belt speed and vice versa. The tension is auto adjusting.
One of the treadmills I've picked up had a AC motor, but also had plastic Reeves pulleys so one could vary the speed of the tread. It was a Lifestyler treadmill from Sears, but I don't recall the model number. Other Lifestyler treadmills I've seen have DC motors. The variable pulleys on the AC motor were adjusted using a small crank and cable system, so it's easy to identify the two types. The DC models use an electronic controller with a rheostat.
On Wednesday I picked up a Lifestyler with DC motor, but the shaft on the motor is threaded with a cast iron flywheel/fan assembly screwed on. I believe it a left-hand thread, but as of now I haven't been able to remove the flywheel. I'm guessing I'll have to disassemble the motor in order to get a grip on the shaft so I can unscrew the flywheel.
Art in Western Pennsylvania
DC Treadmill Motor
All the treadmill motors use a left handed thread (9/16" or 1/2" LH?). The flywheel helps cool the motor and provide inertia and mass for a slower start and helps smooth out the DC motor rotation. This was from my experience.pennview wrote:One of the treadmills I've picked up had a AC motor, but also had plastic Reeves pulleys so one could vary the speed of the tread. It was a Lifestyler treadmill from Sears, but I don't recall the model number. Other Lifestyler treadmills I've seen have DC motors. The variable pulleys on the AC motor were adjusted using a small crank and cable system, so it's easy to identify the two types. The DC models use an electronic controller with a rheostat.
I brought a left handed 3" long bolt and nut and cut the bolt head off. I threaded the flywheel onto the bolt and chucked the smooth part of the bolt in my metal lathe chuck. Locking the LH nut againest the flywheel and using a dial indicator, then moving the flywheel on the bolt and relocking the nut until my flywheel runout was less then .002". I machine the Poly-V grooved pulley part of the flywheel down to 1" and mounted a 1/2" wide single V belt pulley. I filed a flat for the set screw. This took a few hours to accomplish. I switched to a tool post grinder to remove most of the flywheel pulley on the remaining flywheels that I did. Much quicker and machined the last .010"-.020" for the 1" ID belt pully.
