Removing Installing Quill spring
orphiekid
Post by orphiekid »
Could someone please advise me the proper way to remove and re-install a quill spring for My SS Mk 5. Would appreciate it very much. Thanks
orphiekid wrote:Could someone please advise me the proper way to remove and re-install a quill spring for My SS Mk 5. Would appreciate it very much. Thanks
First a question: Why do you want to remove it? It is quite uncooperative in that endeavor.
I assume you are referring to the removal of the spring from the quill shaft, NOT removing the shaft etc. from the headstock or retensioning it.
