Did You Know
Did You Know
that there is a direct link to shopsmith.com from here on the forum.
Scroll all the way to the bottom of the page and click on the copyright 2006 Shopsmith, Inc.
Once there you can return to the forum by clicking on the "go back one page" arrow (top left hand of the page). You will have to click more than once depending on how far into the web page you ventured.
I will now use this daily, when I go there to check on the "current special".
- terrydowning
Alternately, right click and select open in new tab or open in new window.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
Another web browser short cut: In the address bar, you can just type "shopsmith" then hold down CTRL and hit Enter and the browser will add the "http://www." to the beginning and the ".com" to the end and then load the address.
So typing "shopsmith" then hitting CTRL-Enter will take you to "http://www.shopsmith.com"
It works for any address, I just used Shopsmith as an example. Some browsers add more functionality - like doing SHIFT-Enter to use .net instead of .com.
Heath
Central Louisiana
Central Louisiana
It can be shorter than that. Just enter Shopsmith.com (for example) and hit enter. It will automatically take you there.
Abraham Lincoln
Abraham Lincoln
- Ed in Tampa
