Haven't built an outside project in this climate yet, but I have now finished a planter. Made from scrap hardwood, just want to put a clear finish on it that will hold up a little in the hot Arizona sun and heat.
What would u'all suggested? I'm thinking outside poly.
TIA
finish on outside project
Nothing holds up in the desert sun and heat. Just drive around and look at the fascia on houses. Two years, maybe three, and you need to repaint.farley wrote:Haven't built an outside project in this climate yet, but I have now finished a planter. Made from scrap hardwood, just want to put a clear finish on it that will hold up a little in the hot Arizona sun and heat.
TIA
I'd go with an oil finish. You'll have to reapply every couple years, but it wood be easier than varnish to refinish.
