While cutting on the jigsaw with the sanding disk attached I tested the GFI/GFCI and circuit breaker by sanding through the lamp cord. I would not recommend this method of testing it leaves black marks on the sanding disk.
[ATTACH]15453[/ATTACH]
I got my education in this subject back during those days before double insulated power drills. I drilled through a power cord that was under the material I was working on. That was a shocking experience I can do without.garys wrote:Because, Stuff Happens.![]()
Anybody who has never cut, sanded, or otherwise damaged an electrical cord just isn't trying hard enough.
He needed the 'flywheel' effect for the jig saw!:Dbeeg wrote:And you did this WHY?
Question is, was it properly 'grounded'?:Ddusty wrote:I got my education in this subject back during those days before double insulated power drills. I drilled through a power cord that was under the material I was working on. That was a shocking experience I can do without.
