Free(ish) Mark VII parts
damagi
Post by damagi »
Hi All,
Last round went pretty well, so I will continue on. I have a Mark VII that is ready to be an organ donor. Same rules as before -
- items are free
- you pay for pack and ship to your location
- all items are as-is
- you can have more than one 'lot'
- tips/donations appreciated but not required
- first come first serve, but I reserve the right to adjust as I please (ie: local pickup will probably get priority)
This time around I will post in small groups of parts to make it a little easier.
Lot 1 - Quill spring mechanism
[ATTACH]15777[/ATTACH]
[spoken for] Lot 2 - Motor (motor pan goes with the headstock listed below)
[ATTACH]15778[/ATTACH]
[spoken for] Lot 3 - Quill, poly-v, idler, belts
[ATTACH]15779[/ATTACH]
damagi AT gmail DOT com
damagi
Part 2
Post by damagi »
Lot 4 - Wobble Dado blade
[ATTACH]15780[/ATTACH]
Lot 5 - Headstock casting (you will get the pan from the motor as well)
[ATTACH]15782[/ATTACH]
Lot 6 - Speed dial
[ATTACH]15783[/ATTACH]
Lot 7 - Complete Base setup
[ATTACH]15784[/ATTACH]
billmayo
Mark Vii Parts
Post by billmayo »
I will be happy to pay for packing and shippping of the motor if still available.
I am looking for two casters and the bodies that holds the casters. Also the name plates from the ends.
I have a really nice Mark VII missing the above parts that I hope to restore this winter to replace my 10" professional table saw (7 1/2' table) which takes too much room.
Thanks. Have a great week.
Bill Mayo
damagi
Post by damagi »
billmayo wrote:I will be happy to pay for packing and shippping of the motor if still available.
Bill Mayo
Bill - you can have the nameplates and the caster assemblies from the base (which I was going to put up in a couple minutes), as well as the motor.
hdoilcan
Post by hdoilcan »
Ill take Lot 3 - Quill, poly-v, idler, belts
Sending pm
hdoilcan
Post by hdoilcan »
If you can take off the little red nob on the crank handle from the headstock in Lot 5, I could use that also. Or even the whole handle.
Thanks again
