Saw Arbors
Lodgepole
Saw Arbors
Post by Lodgepole »
For Christmas, I recieved a brand new saw arbor from Shopsmith! I was amazed at the large diameter. It is also quite heavy duty.
I also just purchased some additional arbors off of ebay from 2 different vendors.
So, out of the 4 arbors I have, none of them are exactly the same. They will all work for what I need.
But, has anyone seen a chart showing the different sized arbors? And, if so, does it recommend the new heavy duty arbor for a plywood blade versus a combination blade?
Thanks, in advance, for any ideas/suggestions you might have!
Lodgepole wrote:For Christmas, I recieved a brand new saw arbor from Shopsmith! I was amazed at the large diameter. It is also quite heavy duty.
There are the older shorter type with a left hand thread for 1 1/4" blades.
There are the shorter MV 500 arbors that have a right hand thread on the outboard side.
There are the longer MV 510/520 arbors like the one above.
There are several 5/8" arbors and one of those is a big chink of steel.
The 5/8" also have long/short versions.
Then there are the molder/dado arbors of strangely different lengths.
Lastly there are 'universal' arbors that are not intended to be used as a saw blade arbor.
I have purposefully NOT mentioned M10 arbors.
Only 4 versions!:D
jctorok
Post by jctorok »
Hey all, hoping this link still works, here are pictures of the various saw arbors.
http://picasaweb.google.com/PERRYOBEAR/SSARBORS#
Regards
Jerry
Jerry Torok
Spring, TX
Shopsmith PowerPro 520 with Bandsaw, Jointer, Jigsaw, Belt Sander, Pro-planer, Incra 120 Miter Gauge & Incra Miter Express, Incra Twin-Linear
