What is JPW
trubio
What is JPW
Post by trubio »
I recently saw a post that mentioned something called JPW to lubricate the way tubes.
Does anyone know what this is and whether it is better than Minwax? Also, where can I get it?
My old can of Minwax is over ten years old and almost empty.
joedw00
Post by joedw00 »
That would be [ATTACH]16068[/ATTACH]
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
hdoilcan
Post by hdoilcan »
Im pretty sure that's the brand I seen at Lowes the other night, I could be wrong tho.
backhertz
Post by backhertz »
I bought a can of it from HD last night- great stuff.
backhertz wrote:I bought a can of it from HD last night- great stuff.
The can looks to be for the right stuff. You want it to be the "Original" formula - so I have been told.
I buy mine at ACE. Hmmm, if I bought another can now while it is available then the great grandkids will have it when they need it. I am just now using the end of can #2 after twenty years. Got one new can on the shelf.
robinson46176
Post by robinson46176 »
JPW = Easy button...
:cool:
trubio
Which is Better?
Post by trubio »
Thanks, I should have known that "JPW" was Johnson's Past Wax. I thought JPW stood for some kind of exotic, high-tech stuff.
I remember when i was growing up, we always JPW in the house. I think it was even available in the grocery store.
Now the only question is whether I should get more Minwax or the JPW.---Does one seem better than the other for use on the Shopsmith?
terrydowning
Post by terrydowning »
I use Minwax finishing wax. At the time JPW could not be found...
I've never had a negative issue with the minwax.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
pennview
Post by pennview »
I've used Minwax Finishing Wax for years on the Shopsmith without any issues, but that may change as the Minwax has gone missing. While searching for it, I came across some Johnsons, so unless the Minwax turns up, I'll be using Johnsons for a while. I doubt if there's much difference though.
Art in Western Pennsylvania
cincinnati
Post by cincinnati »
Lowe's and Home depot stocks it. Around here Lowe's was a couple bucks cheaper. Located in the cleaning section (Mops, brooms, Buckets etc....)
"Prove to all the world Metal rules the land"
-Judas Priest, Heavy Duty.
