Hand Saw
Hand Saw
Anybody know where I can get one of these???:rolleyes:
[ATTACH]16292[/ATTACH]
Wonder what Gass would think it!;)
- hand saw.jpg (134.79 KiB) Viewed 2994 times
THAT surprises me!
Almost standard equipment for landscapers and timber framers since they cut large timbers all of the time.
Abraham Lincoln
Abraham Lincoln
- trainguytom
Acrobatics
I think you & the saw do a back flip.wa2crk wrote:I wonder what injury would occur if that thing kicked back.![]()
My dad's 1951 10er, 2 more 10er's, same vintage, a Goldie MK5, a 510 shortie with 34inch tubes, bandsaw, jointer, jigsaw, belt sander, a ton of small SS goodies and still looking...you just can't have enough Shopsmith stuff
Back?????????:Dtrainguytom wrote:I think you & the saw do a back flip.
foxtrapper
It's an interesting tool. I've used them before. Not as exciting as you'd think.
Lots of torque action on startup and shutdown. It would turn me about 90 degrees. The gyroscopic effect is quite substantial. That's probably the single biggest difficulty with handling the saw.
It's not particularly powerful. Not with a blade of that diameter. You cut slowly and gently, and take your time. It will bog down and stall quite easily.
Kickback was non-existant. It would stall, but it never tossed itself. I'm sure I could have worked out a way to make it kick. But conventional sized circular saws were much more prone to it.
It's Photo Shopped. The guy's a midget.
Like has been noted, HD sells them as do most decently sized woodworking tool stores.
There's been a few (darned few) times when I could've used one.
Gene
