Shopsmith router
putttn
Shopsmith router
I wondered if anyone is using the Shopsmith router setup and how satisfied are you with it? Using the drill press mode seems strange but maybe it's easier?
Heh, there are many shopsmith router configs:
OPR (old style, standalone)
OPR (new style - mark V mounted)
Shopsmith router table (SPT mount)
Shopsmith router table (mounts on table rails)
Shopsmith Router chuck (on a standard Mark V)
Shopsmith Router chuck (on a power pro)
Speed increaser SPT
Speed increaser SPT
damagi AT gmail DOT com
Ah yes, the router chuck (1/2" or 1/4")putttn wrote:Evidently there's a setup to replace the chuck and use a router type bit.
If you have a standard shopsmith mark V then your max speed is 5200 rpm. Thats 1/2 to 1/4 the speed of standard routers, so you will probably want to take it slow and light. If you have the powerpro then it will go up to 10,000 rpm and you are at the bottom end of standard routers.
The nice thing is that you can go vertical or horizontal, so you can do slot mortising type tasks pretty easily.
Overall, it works ok.
As opposed to chucking a router bit in a drill chuck, there is a "Router Chuck" to be used in lieu of the drill chuck. Is this what you are asking about. Read the CAUTION in the link.
dusty wrote:As opposed to chucking a router bit in a drill chuck, there is a "Router Chuck" to be used in lieu of the drill chuck. Is this what you are asking about. Read the CAUTION in the link.
Got a kick out of reading Shopsmith's description. They said there are two set screws for the spindle and one for the router bit.
- a1gutterman
Sticking to the subject; I have it and have used it. It does the job, but I like my "real" routers better.putttn wrote:I wondered if anyone is using the Shopsmith router setup and how satisfied are you with it? Using the drill press mode seems strange but maybe it's easier?
Tim
And the 'second' set screw is at the(or very close) to the 5/8" to 1/2"(1/4") boundary and will only secure router bits that are long and fully inserted(SS 1/2" bits are long enough).charlese wrote:Got a kick out of reading Shopsmith's description. They said there are two set screws for the spindle and one for the router bit.Actually, it is the other way around - One for the spindle and two for the bit.
