One of my most effective and useful tools
robinson46176
Post by robinson46176 »
A big complex machine? No... It's my Stanley "Short Cut" tool box saw # 15-334.
The cardboard sheath it comes in says that it is a 9 point / 15 inch crosscut saw. It has become one of my most frequent "grab and use" tools. It has teeth much like the Jananese saws but this is still a push saw with a stiff blade. The blurb on the sheath says that it "cuts wood 50% faster than conventional saws". I would say "at least"... I was reminded of how fast it is Friday morning very early when I wanted to cut four pine 1" X 4"s but my wife was still asleep. :) I clamped all 4 of them together in the vise and grabbed this saw. The handle is made so you can use it for a square to mark a cut (and can be re-adjusted for accuracy).
I made a couple of starter passes then cut all 4 of them at once in about 3 seconds.
It has sharpening instructions and there is mention of a sharpening kit # 22-434.
I need to pick up a couple more of these for other locations. I gave it a fresh coat of JPW Friday. I have had it a couple of years and it still looks like new. I keep it in its sheath and plan to make a leather sheath for it.
Almost everybody should have one of these. :)
Gee I hope it is OK if I have 2 of them.
judaspre1982
Post by judaspre1982 »
SS 001.jpg (141.34 KiB) Viewed 2775 times
SS 002.jpg (134.6 KiB) Viewed 2778 times
camerio
Location: Valcartier, just north of Quebec City, CANADA
Post by camerio »
I like the fancy sheath that you made for it .... just kidding you
Maybe you should ask Francis to make you one in leather.
Camerio
MarkV 520 & Band saw
judaspre1982
camerio
Post by camerio »
judaspre1982 wrote:I'm an HVAC guy, so I fix everything with FOIL duct tape:D
Looks like I should squeegee my foil tape down a little better
Dave
I know what IMHO means but not HVAC ?
Camerio
robinson46176
camerio wrote:I know what IMHO means but not HVAC ?
It means he is full of air... :D :D :D
Just kidding. ;)
robinson46176
http://en.wikipedia.org/wiki/HVAC
mrhart
Post by mrhart »
Dave
I believe to be up to code these days, you need to consider retapping with the blue lettered mastic tape....I won't call any local authorities at this point.
R Hart
