dusty wroterjent wrotedusty wroteI'm going to say it again (with a bit more enthusiasm).
Remove the quill and run it at max speed and report what it does. If it runs smooth - report that immediately to Shopsmith (Sue).
Is he allowed to remove the quill?
He was told NOT to do anything to it, is my understanding. Did I read that wrong LOL....
If that is the case and this is part of a problem isolation, I would do as told.
If Shopsmith is NOT in the process of isolated the reported problem, I would not hesitate for a moment to run it up to 10,000. It is designed to do that. If it does not, NOW is the time to find out.
All important however is the verification of this statement.
I agree with you 100 percent. I went back and reread the post and yup, no touchy. I say run it up to 10000 let it blow if it will, if not, I would seriously think about just returning it. I wouldn't put up with it.
TomH wroteSorry this took so long to post, life got in the way of play again!
So I called SS and asked to speak to CS about what was done to my headstock. They referred me to Sue Powell who apparently does the repair work on the headstocks. She was very nice and remembered working on my headstock.
She and another tech also felt the same vibration / chattering that I did and she said they adjusted things to spec and sent it back. I politely expressed that it still vibrated and the quill didn't retract either. She offered to let me send it back again, which for now I've declined.
The more we talked about what was going on she did agree that it was not vibration free like my old head stock and the vibrations I'm feeling are "normal" due to "build up of tolerance issues" in the parts. Which I think translates to crappy manufacturing. She assured me that other than being annoying, there was nothing being damaged inside and while they would be happy to work on it again, she could not guarantee it wouldn't still have issues. I asked if it was anything I could do myself and she gave me a definite NO. Also, shared that when I pushed on it laterally the vibration went away and she didn't think that was significant or useful...again Tolerances.
I did drill some new holes and they are nice a round this time so they must have done something but I still think I could go to Harbor Freight Tools and get a drill press that ran smoother for under $100.
On the quill issue (which begs the question, how did it leave in this condition if you worked on it...and no I didn't as that question) she has advised me to loosen the set screw on the top and to make sure there were no burrs or junk in the groove that would be holding it up.
Sooooooo, not sure what if anything to do next. It drills a decent hole, I can probably get the quill to work so I guess I just chalk it up to "tolerances" and keep moving?
What do you guys think? I just don't want to keep shipping 80lbs of headstock back and forth.
And thanks again for all the help!
Unless I am interpreting that wrong .... :confused:
