Mike wrote
What do you think of the rest of the design if I need to go that way?
I know your question is directed to JPG, but I would avoid cutting your frame rails if at all possible. I would consider reducing the wheel diameter in combination with shortening the stem and moving the wheel axle location closer to the swivel rotation axis.
What are the wheels made of? I would try removing the wheel, then make an arbor using a bolt to hold the wheel in the shopsmith and sand the wheels to a smaller diameter. Then, relocate the wheel axle pin up and over towards the stem. That, with shortening the stem could be enough.
May need to go with a wheel that's not as wide for it to lessen the rotational diameter. The diameter at the edges of the wheel is more than in the center of the wheel.
Thoughts?
