Wow. Lots of good ideas flowing. Thanks a lot!!
etc92guy wroteUse Kroil......I've seen it due some amazing things. I think it penetrates down to .005". What about sanding the tubes to get the top layer off? Then dump it in the tank?
Called them this morning and they offer a money back guarantee if it doesn't work. It can't be found locally in SoCal. (Arnold probably terminated it's use here). They advertise penetrates to 1/1,000,000". Sure would love to see the method they used to validate that!!:eek:
Here's the recipe
Chemical name, CAS#, %
[align=left]Severely Hydrotreated Petroleum Distillates, 64742-52-5, 30-50%
Light Petroleum Distillates, 64742-95-6/64742-88-7/64742-47-8, 30-50%
Aliphatic Alcohols 78-92-2/123-42-2, 1-5%
Glycol Ether, 111-76-2, 1-5%[/align]
Proprietary Ingredients Proprietary 5-15%
Sure seems like a huge % range they work to. That's what my moms chicken soup used to be like....whatever was in the fridge!! She used to even make it with NO CHICKEN!!
JPG40504 wroteDo NOT overlook plain old Kerosene! It penetrates!
I wrestle with kerosene vs. Kyroil. I'd like to try the kerosene first but.....I think I just gotta see what this Kyroil is all about. Flows UPHILL!
Here's the recipe for kerosene
[align=left]Chemical name, CAS #, % by Weight[/align]
[align=left]Kerosene, 8008-20-6 or 64742-81, 100%[/align]
heathicus wroteMy 2nd 10ER had way tubes that were rusted about that bad (yours may actually be slightly worse). What I did was take some strips of emery cloth and lightly sand the tubes........
Apply a little Kroil to all of the crevices where the tubes emerge from the headstock, carriage, etc. Remove the set screws and apply some Kroil in those holes. Wait about 30 minutes or so, then start tapping with a rubber mallet. Apply more Kroil if necessary.
Another note on Kroil. It's kind of expensive........ Just apply a tiny bit to the seams and holes, watch it soak into those seams (even running "uphill!"), then apply a tiny bit more. Eventually you'll see it coming out on the other side and that should be enough.
I like this info heath. It gives me a little hope that with some time and patients, I at least stand a chance. Your 2nd ER was pretty bad. If any of you haven't seen it, check it out:
https://forum.shopsmith.com/viewtopic.php?p=37601&postcount=1
heathicus wroteOh, another thing to check for on the headstock and carriage is the lock wedges. On both of mine.......
This won't be problem. I have already removed both of mine. Mine were the one piece style and came right out
beeg wroteAnd I wonder if loosing the tubes and trying to twist them around might help????
I think this is a GREAT idea beeg. I don't know if the component contact surface area is so great that it would take a ton of torque but it may be worth a try. I'll wrap the tubes with leather belt to protect them. I'll have to see. The tubes are thick enough where they should be able to withstand a pretty decent torque with a hefty pipe wrench.
OK, back to my think tank. Keep the gray matter active and post any ideas. Thanks again.
