Warped Board Question
dusty wrote:I am assuming that the warped piece is a cross member that spans either two legs or two vertical sides.
If I had the problem, I would replace the warped member. You have indicated that that is not an acceptable coarse of action.
With that in mind, I would then plug the existing holes and then drill new holes to fit the warped piece.
A better one!:)
terrydowning
Post by terrydowning »
This would be my course of action as well.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
db5
Post by db5 »
I took JPG's suggestion and filed away the top 1/3 of one dowel and the bottom 1/3 of another and then rounded the flat portion so that they would fit. Then I fitted them, did some more adjustments and refitted. When all looked right I put broken toothpicks in to fill the gaps, glued and clamped them. The result is that both ends are FLAT. My original plan would have left one end at an angle. The warp is now in the center and not even a discerning eye can tell. I'll post pictures after the project is finished.
Thank you JPG. How's the Mark VII restoration going? We need more pictures.
Thanks for the future picture(s) db!I just can't picture the cross piece in my mind. Glad it worked out like it did!
db5 wrote: . . .
Temporarily slow motion. Too many trips to TN last week(3)!
Also in midst of improvising a blind bearing removal tool. The HF cheapie is too big and the 'good' ones are too $$$$$$$:eek: The idler shaft has two bearings in the eccentric like the newer MV one. 5/8" id. I also need to pull a live center bearing(12mm). Still in tear down mode.
db5
Warped Board Update with Pics
Post by db5 »
On the initial post I asked for recommendations on how to straighten a warped (70 year old) board and included a picture showing how much it was warped. JPG had the best recommendation, in my judgement. Here are the results of restoring this bench along with the original picture of the warped board.
The second pic shows the board as it would be if I cut off the dowels and just glued and screwed it to the end piece. Next are the pieces followed by the assembly showing the board attached to each end piece. Not PERFECT but if you weren't looking closely you would never notice.
Great solution JPG.
Bench 2.jpg (62.37 KiB) Viewed 997 times
Bench 1.jpg (64.69 KiB) Viewed 1000 times
Bench 3.jpg (46.87 KiB) Viewed 998 times
Bench 4.jpg (48.42 KiB) Viewed 1001 times
