Jointer mounting tube "rings"
For those not possessing old stuff. Here are the rings and posts under discussion.
[ATTACH]25043[/ATTACH]
old post stop ring.jpg (461.91 KiB) Viewed 1029 times
Thanks for the picture, I was going to do the same if needed.
Yes those are the ones I was thinking of and if you look at post #3 that has the link to the shopsmith.com where they have them listed. I don't know if they have any in stock or not but that is the correct part number....
Several of my SPT's had them all from about 1976.
JPG40504 wrote:For those not possessing old stuff. Here are the rings and posts under discussion.
e.friedl
Post by e.friedl »
I used to service hydraulic cylinders and what you show are spiral snap rings. They are used to retain bearings and packing supports. They come in lots of sizes. One manufacturer is named Smalley, they should be able to steer you to a distributor.
billmayo
Post by billmayo »
reible wrote:Thanks for the picture, I was going to do the same if needed.
These are 1 1/4" Spiral External Retaining Rings if memory is still working.
Install these coiled rings by winding them into the groove on a shaft. No tools are required for installation so they&#8217]http://www.mcmaster.com/#retaining-rings/=ryxzlj[/url]
"Wild Bad Bob"
Post by "Wild Bad Bob" »
Thanks guys!!! But my Bad!!! I was thinking of the ones TerryD posted in is attachment, I thought they were on my Greenie jointer. Just risked spilling my Martini and went to the garage, freaken cold and rainey again, as usual I was wrong!!! They both have the ones JPG posted pics of and the Goldie has those on them, that jointer is on the floor and I could not see them well. How easy is to move them on the tube to get the height adjustment? I would think the collars like TerryD would slide easy and then tighten the set screw. Why not use those?
Good to here from you Bill M!
rbursek wrote:Thanks guys!!! But my Bad!!! I was thinking of the ones TerryD posted in is attachment, I thought they were on my Greenie jointer. Just risked spilling my Martini and went to the garage, freaken cold and rainey again, as usual I was wrong!!! They both have the ones JPG posted pics of and the Goldie has those on them, that jointer is on the floor and I could not see them well. How easy is to move them on the tube to get the height adjustment? I would think the collars like TerryD would slide easy and then tighten the set screw. Why not use those?
The 'vertical' aligning is done by adjusting the SPT to the tubes. With the jointer, wedges/props are recommended!;)
billmayo
Post by billmayo »
The collars are not needed. The collars with set screws would be a redundant way to position the SPT tubes when the spiral snap rings stop the downward movement of the tubes. Plus the SPTs mounting looks a lot cleaner than using the collars. You use the tube set screws in the SPTs to adjust the height of the SPT. I did have cut off the top of a few tubes that bottomed out in the SPT as the tubes were longer than the original tubes used.
