Anyone dealt with onyx ?
djr
Re: Anyone dealt with onyx ?
Post by djr »
I have used these mounted in a multi layer etched glass picture. They have worked for a couple of years with no problem for me.
http://www.lowes.com/pd_696-24994-HTP90 ... facetInfo=
roy_okc
Post by roy_okc »
I've used LED strips from Amazon on a few projects, like these http://www.amazon.com/LEDwholesalers-30 ... wholesaler. Around $20-25 when you add a power adapter. These can be cut at the indicated spots so you can run a bunch of short strips back and forth and solder wires onto the pads to make the bends.
A few people I know have used them for under-cabinet and bookcase accent lighting and ended up using fewer than expected due to how bright they are.
Roy
Laser engraver
masonsailor2
The continuing saga
Post by masonsailor2 »
I got the onyx frames made and will attach them to the cabinets hopefully today. I set a frame on one of the cabinets and put a flood light under it for a lighting test. It going to take a lot more light than I thought to get the level of illumination the boss wants. My newest theory is to use 3/16 mirror as the tray to glue the led's to. Not only will it give me more lumens with the bounce back but also I believe the glass surface will allow for better adhesion of the light strips. We will see.
Paul
masonsailor2
Well we are all moved in and the shop has been functional for a few weeks. I have managed to get several projects finished the last two weeks. First were the onyx topped bedside stands and then the living room coffee/display table and two end tables. I also included a picture of us preparing the light panels for the onyx. All were made from alder and Honduran mahogany with Watco finish.
Paul
You have made some drop dead gorgeous furniture!!! :cool: :cool: :cool:
Very nice, Paul! :D Beautiful workmanship.
