Iron table bandsaw -- label for cover
- paulrussell
Re: Iron table bandsaw -- label for cover
Thanks guys. Photos when finished.
- paulrussell
Oops
You are welcome.
Once would have sufficed!
- paulrussell
Today was a big day for my bandsaw. I got it about four years ago from a fellow who found it in a collapsed barn. At the time I rebuilt it to the point that is was functional, but far short of pretty.
This week I decided to give it a second round of rebirth. Today I took it to a friend's shop and walnut-blasted the white corrosion from the inside of the body. Right now she is in the basement after a fresh coat of primer.
I ordered a couple new labels, salvaged the serial number sticker, and also ordered the SS bearing upgrade. If there is a round three of rebirth, I'll look into the double-bearings, but for now it is single-bearing upper and lower, and double-bearing guide.
First on tomorrow's list is to drill and tap to add a nylon tensioning bolt to the guide-column. Then on to a first coat of topcoat.
- paulrussell
Free beer at my house to the first person to figure out why I used a 5/16-18 nylon screw instead of 1/4-20 when I modded the guide bracket.
You went with what you had? i.e. tappaulrussell wrote:Free beer at my house to the first person to figure out why I used a 5/16-18 nylon screw instead of 1/4-20 when I modded the guide bracket.
Orrrrr you first drilled a 1/4" hole.
- paulrussell
Second guess wins!!
In my only defense I only drilled half a 1/4" hole.
It will 'work' better anyway(assuming no interferences).
- paulrussell
Swatting a fly with a sledgehammer. Preparing to cut window opening with my CNC.
Waiting plexi.
Homebrew serial number tag to replace original removed for painting.
- paulrussell
Replica label
Nylon bolt mod
My version of a label.
Progress so far. Anybody got a spare aluminum cover knob in their junk box?
