To Hang or Not to Hang?
algale
Re: To Hang or Not to Hang?
Post by algale »
Beautiful! I've started one of these and got distracted. Need to finish it!
The added weight is on the clamping bar, not the casting.
I think it stout enough. Realize it will also be loading the two screws and casting threads.
masonsailor2
Post by masonsailor2 »
To quote Philippe Pétain "What could possibly go wrong ? "
Paul
recurvearcher
Post by recurvearcher »
I have mine hung from the tubes. Word of caution, if you overload it , the legs will deflect and your caster bars will pop out of the bracket. I'm toying with the idea of making mine free standing.
jjbuzard
Post by jjbuzard »
recurvearcher wrote:I have mine hung from the tubes. Word of caution, if you overload it , the legs will deflect and your caster bars will pop out of the bracket. I'm toying with the idea of making mine free standing.
How many tons did you have in it?
My thought exactly. Good grief Charley Brown. :) :eek: :eek: :eek:
Beave2012
Post by Beave2012 »
I go with 2 u-shaped brackets to hang the unit. It's nice to bring the tools with you. But I hate the original design to have permanent hangers. Mine are held in by 2 bolts on each side. Take them out and leave the cabinet in place. I consider it a convertable.
If stress on the tubes is a concern... Could always add casters to the cabinet and then slot the hangers so they float on the bolts and simply guide them with the shopsmith.
-Beave
jjbuzard
Post by jjbuzard »
I decided to hang mine, with a quick disconnect.
When the Shopsmith is raised the Cabinet goes up with it and moves as a unit with the Shopsmith., when lowered the cabinet sits on the castors.If I want to move the cabinet away from the Shopsmith, unclip the lynch pines and roll it away. This way the only time there is added weight to the Shopsmith is when the whole unit is raised and being moved.
I used tape to lay out holes for U-Bolt
Guide for hole spacing.jpg (577.12 KiB) Viewed 7864 times
Made the U- Hook using 1 " Wide Aluminum bt 1/8" thick, bent it over a piece of Bench Tube.
Bending U-Hook.jpg (848.18 KiB) Viewed 7864 times
Completed U-Hook
Completed U-Hook
All of the hardware for each hook
Hardware needed.jpg (731.39 KiB) Viewed 7864 times
Linch Pin ready to install with centering spacer (White Object wit slot cut in it for U-Bolt.
Lynch Pin about to be installed, white thing is space to kkep Lynch pin centered.jpg (1.02 MiB) Viewed 7864 times
Everthing installed
Everthing installed
U-Hooks Installed.jpg (1 MiB) Viewed 7864 times
ecom1
Post by ecom1 »
I really like the look of masonsailor2's cabinet!
I have been haven the same thought, and think when I come to build one, it will be removable and have casters on the bottom to wheel out of the way as necessary. I've also toyed with the idea of working a dust collection top into the project.
For those who have made them, do you find the space useable, or is it a little low for ease of use?
Shopsmith: 2 Mark V 510 (1988,1993), bandsaw, jointer, mounted planer, belt sander, scroll saw, strip sander, lathe duplicator, conical disc sander, biscuit joiner, free standing router table with Jointech IPM-1
Other stuff: Bosch glide mitre, Ridgid 13" planer, Rikon drill press, routers, drills, and other toys
jjbuzard
Post by jjbuzard »
What is a masonsailor2's cabinet?
