Mark VII Belts
n240sxle91
Re: Mark VII Belts
Post by n240sxle91 »
I laid my tape measure on the ground, marked a spot on the belt, and rolled it on the tape measure until I came back to my marked spot. The belt I ordered is the exact same size, and I ordered it as a 29.5"x1/2" belt. So, I measured correctly because the replacement belt is the identical size.
Re: Mark VII Belts
n240sxle91 wrote:I laid my tape measure on the ground, marked a spot on the belt, and rolled it on the tape measure until I came back to my marked spot. The belt I ordered is the exact same size, and I ordered it as a 29.5"x1/2" belt. So, I measured correctly because the replacement belt is the identical size.
Outer circumference.
n240sxle91
Re: Mark VII Belts
Yup
Any other way you would do it?
Re: Mark VII Belts
Manufacturer and Part Number?
I am trying to gain greater understanding.
n240sxle91
Re: Mark VII Belts
I ordered the "D&D PowerDrive A27.5/4L295 V Belt, A/4L, Rubber, 1/2" x 29.5" OC". However, any similar 29.5" x 1/2" belt should be the same.
Re: Mark VII Belts
n240sxle91 wrote:I ordered the "D&D PowerDrive A27.5/4L295 V Belt, A/4L, Rubber, 1/2" x 29.5" OC". However, any 29.5"x1/2" belt should be the same.
Thank You!
A27.5 = 1/2width x 27.5 ID.
4L295 = 1/2width x 29.5 OD.
Forgive my persistence. This is contrary to my previous conclusion.
It has forced me to reevaluate the correct size of a Mark 5/V belt.
I now believe a Mark 5/V new belt is 25.5 to 26 inches od. I have looked at several used belts I have, and they fall within that range.
I also recently acquired a NOS 507490 belt. Had not measured it before tonight. 29.5" :rolleyes:
So I gotta agree with your conclusion.
Sheez now I gotta go back to the MVII reassembly thread and 'correct'. :cool:
n240sxle91
Re: Mark VII Belts
I'm glad us Mark VII owners now have easy access to motor belts! I ordered three more replacements (for a total of four). Just in case for some reason the belt isn't available down the road. I'm guessing that won't be a problem, but for a little less than $5 a piece it's worth having a little peace of mind! I'll dress them and store them inside out, so they should have a long shelf life.
One more mystery of the Mark VII solved!
hobbies
Re: Mark VII Belts
Post by hobbies »
n240sxle91 wrote:I ordered the "D&D PowerDrive A27.5/4L295 V Belt, A/4L, Rubber, 1/2" x 29.5" OC". However, any similar 29.5" x 1/2" belt should be the same.
So who did you order from?
n240sxle91
Re: Mark VII Belts
I'm not sure about the rules here, some forums don't want you listing store names. So, I'll just say that I ordered it online from a "South American" rainforest. :)
If you do an internet search for "D&D PowerDrive A27.5/4L295 V Belt, A/4L, Rubber, 1/2" x 29.5" OC" it'll be one of the first ones to come up.
hobbies
Re: Mark VII Belts
Post by hobbies »
THank you
