Picture frame mode
Re: Picture frame mode
Consider using bamboo skewers for dowels. :)
masonsailor2
Post by masonsailor2 »
For the dowels they sell an assortment of 1/8" dowels by Handi Craft on Amazon and probably everywhere else. They are of a variety of species so it's easy to match to whatever wood you have. And of course using the disc sander and a very simple jig you can make your own of any diameter.
ChrisNeilan
Post by ChrisNeilan »
This has to be the best framing clamp jig I have seen, and the most simple. Thank you for sharing!
Chris Neilan
DITTO!!!
masonsailor2
Finished the picture frame. Here are some pics of the doweling.
sehast
Post by sehast »
Very nice. Hardly can detect the dowel. Assume it is from the same type of wood as the frame?
masonsailor2
Yes I made them on the SS from the same piece of wood. I prefer them over the dowels because I can give them a slight taper for a better fit and they blend in almost completely
Paul
sehast
Post by sehast »
What kind of jig do you use with the disk sander to make them?
masonsailor2
The jig is just a taper guide so as you twist and feed the square stock through it rounds it to the size you need. It works much better with the conical disc but I am usually to lazy to change discs. The flat disc works fine. You just spin the stock as you feed it through.
Paul
