Vintage chestnut, vintage clampage
nuhobby
Re: Vintage chestnut, vintage clampage
Post by nuhobby »
I finally got a little more time to work these old boards. The basement is showing about 12% R.Humidity this early January (lots of forced-air heat going on!). I planed them out some more times since they were curving a bit from dryness, then committed the joints layout. This will put things in place for subsequent power-routing some grooves inside the case:
Chest Joints.JPG (122.97 KiB) Viewed 6890 times
Chris
nuhobby
Post by nuhobby »
Doing a bit more with both power routing and manual rabbeting....
Fitting Chestnut Shelf.JPG (126.17 KiB) Viewed 6828 times
Chestnut Carcass Glued.JPG (111.64 KiB) Viewed 6828 times
nuhobby
Post by nuhobby »
I finally finished this little guy; it will be for a nephew with a birthday coming up. I'll probably enclose some educational material on "wormy chestnut" as well.
By the way, the chisel in the last photo is fitted with a chestnut handle from an online seller. It's really what inspired me to seek out this type of wood :)
Knob for Josh's chest.JPG (116.41 KiB) Viewed 6776 times
Josh's chest closed.JPG (104.55 KiB) Viewed 6776 times
Josh's chest open.JPG (94.24 KiB) Viewed 6776 times
Happy woodworking!
Chris
algale
Post by algale »
Nicely done!
rjent
Post by rjent »
Absolutely beautiful!
I assume a magnet and plate keeps it closed?
Nicely done!
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
nuhobby
Post by nuhobby »
Thanks very much! I put a rare-earth magnet pair in the knob-hole and in a little wood horseshoe inside the case, under the top panel.
The *other* thing besides magnets to get the door to stay closed is to not tighten the hinge screws too much. Same thing I encountered in 7th grade Shop class, "competing" hinges on a lid tend to bind up and not stay shut, so it's best to only use moderate torque on their screws.
