Help needed in the UK
everettdavis
Re: Help needed in the UK
Post by everettdavis »
I realize you are in the UK and your motor may be 220VAC
In the US most are 110VAC
The external Motor Start relays used on motors without an internal centrifugal motor start switch might resemble this configuration.
The Relay itself would be connected internally as I have drawn it with the overly of the schematic representation of coil and contacts below.
Motor Start Relay with imbedded Schematic.png (1.14 MiB) Viewed 5663 times
The GE relay I am most familiar with here is this type
ge 3-4hp motor start relay numbers.jpg (82.8 KiB) Viewed 5663 times
The relay you mention is a DC relay, I presume mounted on a circuit board of sorts that provided the AC rectification of the AC to convert it to DC for the relay coil. Not having pictures to reference is a disadvantage.
I don't have much on UK Shopsmith info. Jacob Anderson might know more.
Check out some of his free videos on Shopsmith at https://jacobs-repairshop.com/youtube-videos/
Everett
Realize that a start relay is not a typical relay. Coil sensitivity is calibrated to match the emf generated in the start winding when the motor is up to speed and the relay has a normally closed contact to disconnect the start winding from the power source(mains).
Hobbyman2
Post by Hobbyman2 »
since we are discussing relays and their coil voltage AC VS DC ,, I was all ways taught as follows ,,
AC coils can be used with DC as long as you dont exceed the power rating of the coil.
I found this on line while doing the search https://www.google.com/search?client=op ... 8&oe=UTF-8
any one else have any thoughts if this is correct ?
everettdavis
Check out this page. 3ARR3 relay It looks like the replacement for the GE#.
https://www.zettlercontrols.com/products/pdfs/3arr.pdf
Everett
Bushell5
Post by Bushell5 »
Thanks everyone
Hobbyman2
Post by Hobbyman2 »
everettdavis wrote:Check out this page. 3ARR3 relay It looks like the replacement for the GE#.
Everett
Good link thanks for posting it
