WHERE to drill the holes?
Hi guys,
Remember back to your shop class in HS?
I think these might refresh your memories.
[ATTACH]2987[/ATTACH]
[ATTACH]2988[/ATTACH]
For the three across use the scale at 12" edge to edge, then mark at 3", 6" and 9".
For the 4 the other way use the scale at 15" and mark at 3", 6", 9" and 12".
BINGO!
Sometimes there is a time for math and sometime use one of those tricks from your youth.
BINGO!
- three across.jpg (364.4 KiB) Viewed 6000 times
- by 4 the other way.jpg (358.6 KiB) Viewed 5997 times
FWIW, the pounding benches that I remember from my youth had dadoed end blocks.
if you are going to dado the end blocks, don't forget to subtract twice the depth of the dado from the length of the available board when you do the layout.
making the gap between the end blocks and the closest pegs a little bigger than the peg-to-peg spacing is not a bad thing. that makes it easier to hit the pegs without hitting the end block.
ER10 awaiting restoration
- a1gutterman
That is a pretty cool trick, Ed! My shop teachers never gave me that one. We always had to do the math.reible wrote:Hi guys,
BINGO!
Tim
Shop Trick
Tim Too bad it won't work for gutters!!:rolleyes:a1gutterman wrote:That is a pretty cool trick, Ed! My shop teachers never gave me that one. We always had to do the math.
- a1gutterman
Compound Corners
The material is Soooo thin, how can it be a 'compound' mitre???:pa1gutterman wrote:Yes, oh well. I do know one or two tricks about them though. Compound corners are knot the same on a gutter, as they are with wood!
Good catch there iclark!!:D He will be needing that extra space.iclark wrote:FWIW, the pounding benches that I remember from my youth had dadoed end blocks.
- perryobear
Hi everyone,
For anyone following this thread and searching their memories about what a Pounding Bench is all about, here is a link to the Shopsmith plan. It also contains some ideas on the other essential item; The mallet!
This is another timeless toy, Beeg I'm sure that your granddaughter will love it!
http://www.freekidsbenchplans.com/
Regards to all,
Dennis
Regards to all,
Dennis
Thanks for the reminder, but THIS TIME I did remember to subtract the dado depth. The board is actually .75 inches longer than stated.iclark wrote:if you are going to dado the end blocks, don't forget to subtract twice the depth of the dado from the length of the available board when you do the layout.
