Repair of a broken carriage casting - Photos
heathicus
Post by heathicus »
thainglo wrote:Taping off all those holes in the carriage for painting is a great time! I was planning for the next one I strip and repaint to fab up a set of plugs that will snug into each size hole. Something like PVC pipe or wood dowels that can be turned down to fit...
When I was restoring my first 10ER a while back, I fought with PVC and dowels until my wife suggested something that worked perfectly. Magazine pages. They're thick and slick enough to not soak up much paint. Just tear out 3 or 4 pages, roll them up together, stick them in the hole, then unroll until they fill the hole. Simple and effective.
These would work great. These are cheap versions and available in the borgs. Maybe not worth the price unless you are doing multiples.
http://www.lowes.com/lowes/lkn?action=p ... lpage=none
http://webstore.petersenresources.com/143-5Waterlinestub%20plugs.aspx
dusty wrote:These would work great. These are cheap versions and available in the borgs. Maybe not worth the price unless you are doing multiples.
Did the Lowes link work when you first posted it? Appears to not work now!:(
tom_k/mo
Post by tom_k/mo »
It works for me...
tom_k/mo wrote:It works for me...
I get a page not found and a link to their main page. I do not think that is what Dusty had in mind.
tom_k/mo
Post by tom_k/mo »
JPG40504 wrote:I get a page not found and a link to their main page. I do not think that is what Dusty had in mind.
Odd, because I get a detailed listing page for:
Plumb Pak
1-5/8" - 1-3/4" White Rubber Duo Fit Drain Stopper
Item #: 24569 Model: PP22006
Try THIS link and see if it works any better...
mickyd
Post by mickyd »
Normally I would coat the ID of the holes with thin coat of Vaseline instead of tape but I was experimenting. Vaseline works the best. Just don't get any on your surfaces you want paint to stick to.
Sunny San Diego
mickyd
Post by mickyd »
mickyd wrote:Normally I would coat the ID of the holes with thin coat of Vaseline instead of tape but I was experimenting. Vaseline works the best. Just don't get any on your surfaces you want paint to stick to.
Manufacturing facilities use these to mask off holes for painting and plating. If you can find a place that sells singles, go this route FOR SURE.
Sunny San Diego
tom_k/mo wrote:Odd, because I get a detailed listing page for:
Plumb Pak
NOPE! Same result! Now that I know what IT is, I do NOT need to go there!
I just tried with IE, it worked. Firefox got scre--d again by Mr. Gates.
beeg
Post by beeg »
JPG40504 wrote:NOPE! Same result! Now that I know what IT is, I do NOT need to go there!
More and likely a lazy developer didn't use "standards". But MY Firefox has always worked at that site.
