Stop Collars
enyoc
Post by enyoc »
mbcabinetmaker wrote:I need them for setting the depth of my accessories on my new SPT benches to keep the tubes above the drawers.
Sorry to go off topic, but how thick of a surface do the accessories penetrate? I.e. if it's 3/4" thick ply I'd think they'd tend to want to lean. I'm curious as to what you think is enough supporting material to prevent this. Can you take a pic of, for example, the bandsaw in and out of the bench?
Thanks!
JC
Hampden Twp, PA
Bought, restored and sold a 520 before I knew what I had (and should have kept) - Now I found religion and I'm working on restoring a 500 and a 10E.
mbcabinetmaker
Post by mbcabinetmaker »
affyx
I have them in 2 layers of 3/4 inch plywood using 1 1/4 inch holes. You have to be dead on with your drilling for this to work but it works well. I will post some pictures in the next day or so.
Mark
2017 Power Pro Mark 7
enyoc
Post by enyoc »
mbcabinetmaker wrote:I have them in 2 layers of 3/4 inch plywood using 1 1/4 inch holes. You have to be dead on with your drilling for this to work but it works well. I will post some pictures in the next day or so.
Thanks Mark!
JC
Hampden Twp, PA
mckenziedt
Post by mckenziedt »
For you Shopsmith owners in Canada, the Grainger product line is distributed by Acklands. They have about 150 branches in most major cities as well as smaller cities in oil/mining/logging/agricultural areas. Don
D.McKenzie
520,510,mini 500,10ER,10E,Band Saws,Jointers,Scroll Saw,Jig Saws,Belt Sanders,Strip Sander,Speed Reducer & Increaser,Pro-Planer,Mortiser,Grinding wheel,Sharpening guides,Lathe Duplicater,Biscuit Joiner,Tendon Jig,Ring Master,Oneway Chuck, Most Arbors,Bits,Blades,Chucks,Cutters,Fences,Safety Items,Sanding & Sawing Items,Shop Accessories,Spare Parts
mbcabinetmaker
Affyx and other interested parties, this is my attempt at describing how I drilled the holes in my SPT storage benches. As previously stated they are 1 1/4 inchg holes. SPT holes need to be 7 inches on center, Mark 5 main tables 12 inches on center and 510/520 main tables 15 1/2 inches on center.
[ATTACH]5637[/ATTACH]
[ATTACH]5638[/ATTACH]
This is showing the band saw in place and then removed. Look closely and you can still see my lay out line. Also notice that I have routed a small round over at the top of the holes.
[ATTACH]5639[/ATTACH]
[ATTACH]5640[/ATTACH]
This system requires very accurate measurements. I draw the lay out line and then pull my tape and lay out both holes at the same time. Here I mark 7 inches and 14 inches with an awl.
[ATTACH]5641[/ATTACH]
On smaller pieces you can drill on the SS. My pieces required drilling after assembly and I used this drill guide from Woodcraft. The holes would be very hard to keep straight without some type of guide. I have not had a problem with fit but if you get one to tight you can always ream the hole out with a 1 inch sanding drum in a drill. I recommend a sharp forstner bit and I use Freud Precision Shear Forstner Bits. http://www.freud-tools.com/frprshfobi.html
Mark
mbcabinetmaker
The jointer will not work with this system if it is fitted with dust collection. I handled it with the SS SPT base.
[ATTACH]5643[/ATTACH]
[ATTACH]5644[/ATTACH]
Mark
enyoc
Post by enyoc »
'tis a thing of beauty! thanks for the posting!
JC
Hampden Twp, PA
Ed in Tampa
Post by Ed in Tampa »
Mark
I use three plies of 3/4" and I also rasp out the holes so the SPT concentric support tubes fit. My SPT like my Band Saw sits down on my holder so the bottom casting is fully supportted. Probably over kill but I like to spead out the weight of the machine on to the whole casting for storage.
Ed in Tampa
Stay out of trouble!
