Well you made me get out my hardly used 2 bearing quill to check for 'wobble'.rlkeeney wrote:trainguytom
He responded quickly to all my emails and seemed quite concerned that I was happy with my purchase. I am.
The odd thing was that after reading all the docs I could find, watching numerous videos, searching forums, and googleing no one said any thing about the spindle wobbling around like that. After I had already decided it was OK after all the seller mention it in an email.
I would buy from him again.
No play is evident by just handling it. Closer examination by applying lateral pressure to the end of the splined shaft does create slight deflection which appears to be caused by play in the rear bearing(this was a surprise to me).
I Have had single bearing quills with 'sloppy' bearings that did indeed cause the splined shaft to flip about.
IMHO the purpose of the second bearing is to reduce the flop caused by a loose single bearing. Any significant floppiness of the shaft in a quill would indicate to me a need to replace bearing(s).
The function of the nylon sleeve does not include keeping the shaft in line. Its purpose is to transfer rotation to the quill while allowing the shaft to move in and out.
FWIW me thinks ya should replace the bearings.(I assume the shaft is not bent)
