50th Annivesary Edition?
nuhobby wrote:Hey Heath, has your profile grown? 3 x 10ER's now, I see?
My newish Mk. 5 has the chromed bench-tubes and unfinished (high-nickel steel?) way-tubes. Chromed bench tubes seem to be a recent-era thing.
I have wondered if some of the occurrences of difficulty holding position(headstock and carriage lock) were not the result of super smooth chromed way tubes.
IIRC My goldie has chrome plated way tubes, but they are not shiney smooth. They have obvious marks from grinding(when new). The bench tubes are painted.
SDSSmith
Post by SDSSmith »
JPG40504 wrote:I have wondered if some of the occurrences of difficulty holding position(headstock and carriage lock) were not the result of super smooth chromed way tubes.
Interesting......I do not think I have ever seen a Mark V (nor a 10E/ER) with chrome plated way tubes.:confused: The only plating/painting I have seen is on the bench tubes. Early models such as your goldie had paint. From sometime in the 80's on, the bench tubes have some kind of plating. In that time span, the later years have been shinier.
Rob in San Diego
SDSSmith wrote:Interesting......I do not think I have ever seen a Mark V (nor a 10E/ER) with chrome plated way tubes.:confused: The only plating/painting I have seen is on the bench tubes. Early models such as your goldie had paint. From sometime in the 80's on, the bench tubes have some kind of plating. In that time span, the later years have been shinier.
It is possible that my 'recollection' is of 'nickle-chrome' plating. It has a very rough surface that one does not associate with chrome plating(aka antique automobile bumpers from the same 'era'). It does not however resemble polished 10E tubes. It may do so when I refurb the goldie and 'spin those original tubes. Howsomever the original way tubes will be replaced with 10E tubes(thicker/heavier) and will then become occupants of the 'available spare parts' pile.
P.S. My 510 has something if not chrome. Perhaps just a different grade steel???
judaspre1982
Post by judaspre1982 »
terri's potting bench 002.jpg (132.79 KiB) Viewed 2829 times
terri's potting bench 003.jpg (136.07 KiB) Viewed 2821 times
A quick review of my 1962 manual reveals the same descriptions etc. Hard chrome it is. Not very shiney(ever). Grinding marks still visible after all these decades. Bench tubes painted gray.
wiredone
Post by wiredone »
JPG40504 wrote:A quick review of my 1962 manual reveals the same descriptions etc. Hard chrome it is. Not very shiney(ever). Grinding marks still visible after all these decades. Bench tubes painted gray.
I worked in a machine shop in the 70s as an apprentice where we made those tubes.
The finish ( in machine shop vernacular ) is industrial chrome.
Just not as many layers and the polishing under the chrome is not present.
www.wirewerkes.com
Hiding in a Joshua Tree.
wiredone wrote:I worked in a machine shop in the 70s as an apprentice where we made those tubes.
That certainly makes sense and explains much! Thanks!!!
