10E Speed Changer Crank vs. Headstock Lock
heathicus
Post by heathicus »
Make sure you also have a washer between the speed changer and the headstock. I think the main purpose of this washer is to provide support behind the nut so the main bracket of the speed changer isn't broken in half (as evidenced by a recent eBay auction that was linked to elsewhere on the forum). But, it may also provide an extra little bit of clearance.
Heath
Central Louisiana
Cavediver
Post by Cavediver »
Will do, and thank you for the help!
On the subject of belts, do you prefer the standard belts or the cogged version? The belts provided with the speed changer are in fair shape and don't need replacement, but I might as well go ahead and do it while it's still pulled apart.
heathicus
Post by heathicus »
Cavediver wrote:Will do, and thank you for the help!
Cogged. They're more flexible and allow for a tighter radius. But, I don't think they make the original lengths anymore. Or else they're just incredibly hard to find. The workaround is to get one belt slightly longer and the other belt slightly shorter. I don't remember the lengths off hand. I highly recommend skip at MCKtools as the source for new belts. http://mkctools.com/10erparts.htm
Heath
Central Louisiana
The cogged belts are a definite improvement. They are more flexible(important with small diameter pulleys). The speed changer pulleys are very small!;)
IIUC, the belt length difference is 3"
Notes(penciled in by a PO) on my 'documentation' states 22 1/2 and 25 1/2.
Assuming adjustment range of the motor mount and speed changer arm, either 22,25 or 23,26 belts MAY work.
I decided upon 22,25 for mine.
Cavediver
Post by Cavediver »
Excellent! I'll get a set ordered today :)
Cavediver wrote:Excellent! I'll get a set ordered today :)
Get em from Skip!!!!!!!!!!!!!!!!!!!!!!!:cool:
Great minds travel similar paths!!!!:D
[ATTACH]24679[/ATTACH]
Notice the belt sizes! 4L220 = 1/2" x 22" etc.
10E speed changer belts.jpg (239.63 KiB) Viewed 1240 times
dgale
Post by dgale »
I sure like the look of those variable speed/reversable motors Skip makes for the 10ER
'82 Mark V 500 #96309
Cavediver
Post by Cavediver »
Success! You guys ROCK!
Moving the screw to the other side of the ears has solved the issue. I picked up a threaded stud and a couple of jamb nuts today at the hardware store, so now I'm just waiting on the belts. In the meantime I'm going to try to add a proper strain relief and revamp the ground wire connections on the motor and headstock. After that, I'll be back to turning!
Thanks everyone!
skou
Post by skou »
dgale wrote:I sure like the look of those variable speed/reversable motors Skip makes for the 10ER
You're not the only one. Without a doubt. the single best addition to an ER. Period!
Love mine!
steve
