Dust collection with bandsaw
fjimp
Post by fjimp »
michaeltoc wrote:Getting back to the original question - I would guess that the grid is a safety screen to prevent you from sticking your fingers inside the bandsaw while it is running. It's probably OK to remove, but then you have a potential safety hazard.
I cut out the grid the last time we discussed this topic. I does appear to pull out more sawdust. I have seen no negatives to the modification. fjimp
F. Jim Parks
Lakewood, Colorado:)
fjimp wrote:I cut out the grid the last time we discussed this topic. I does appear to pull out more sawdust. I have seen no negatives to the modification. fjimp
Just do NOT stick your finger(or anything else) into the hole while saw is running!:D
fjimp
Post by fjimp »
JPG40504 wrote:Just do NOT stick your finger(or anything else) into the hole while saw is running!:D
Why does your suggestion make me grin? I thought the whole idea was to have the hole covered up with the hose while the band saw is running. fjimp:confused:
F. Jim Parks
fjimp wrote:Why does your suggestion make me grin? I thought the whole idea was to have the hole covered up with the hose while the band saw is running. fjimp:confused:
Hoses sometimes fall out(they go limp or something).(Maybe not enough suction).:D
skowznofski
Post by skowznofski »
I don't think the grid has anything to do with strength, the retrofit kit doesn't have any cover / grid & it works fine. Also, most other connectors on hoods are open. I think it's a safety issue, they'd probably close it completely if they could. Ultimate safety but I think air flow would suffer:D
