Dust collection with bandsaw
kd6vpe
Post by kd6vpe »
I bought the new bandsaw cover with the little window and dust port. The dust port has a plastic grid in it ths is part of the mold and it keeps getting clogged with saw dust.
Have any of you ran into this? could the grid be cut out? Or would that comprimise something. :confused:
SS 500 upgraded to 510; SS bandsaw; SS jointer
SS Oscillating Drum Sander; Universal Lathe Rest;
lathe duplicatior, shaper fence and shapers; SS Belt
Sander
Jim
www.youtube.com/kd6vpe
8iowa
Post by 8iowa »
You have brought up a good point. My original bandsaw bought in '83, did not have a dust collector port. Then, a few years later, with the introduction of the DC3300, a dust port retro kit was offered for the bandsaw. One of the first things I had to do per instructions, was to cut a large round hole in the cover - thus no "grid". It worked great.
The dust collection port on the new bandsaw cover is molded separately, and then glued onto the cover. When the cover itself is molded, it has a lare hole in it. The grid is part of this separate piece. The answer could be that the grid helps to get a uniform flow of molten plastic during the molding process. In looking at this part the plastic is injected at the rim. I am speculating of course, however, I was in the plastic injection molding business for a brief period.
john
Post by john »
As 8iowa said, this is a good point. I had never thought of it, either for the bandsaw which seldom clogs, or my router table dust port which does frequently when routing pine.
I had alway thought it was to prevent large pieces from getting sucked in and damaging the impellers, but that should not be a problem on either of these tools.
I don't think cutting at least one cross piece would affect the stucture.
John
Dust Collection with bandsaw
What did Shopsmith Customer Service (1-800-543-7586) have to say about this problem?
How many complaints have they had to field? What was their solution?
kd6vpe
Post by kd6vpe »
Dusty,
I have not called Customer Service. I thought I would start here and see what kind of responses I got back from the usres first. This is a faily new product for them. My bandsaw is an old Magna that I am upgrading
Sander
Jim
fjimp
Post by fjimp »
Jim, I hope you will post what you learn from Shopsmith. I have a newer bandsaw with the grid and find I that grid seems hamper the dust flow. I need to clean the inside of the bandsaw every time I use it. I would love to cut that grid out. Jim
F. Jim Parks
Lakewood, Colorado:)
kd6vpe
customr service update
Post by kd6vpe »
Jan said,
She did not think it would be a problem to cut the grid out In fact she is going to go talk to engineering. She suggested maybe a dremel tool would work to cleanly remove the grid. I will attempt this this weekend and let you know how it goes.
Sander
Jim
kd6vpe
Post by kd6vpe »
Here is what it looks like now. I used a scroll saw blade and hand cut out most of the grid leaving a cross section just for strength
bandsaw dust port mod.jpg (60.71 KiB) Viewed 1885 times
Sander
Jim
john
Post by john »
Jim:
Thanks for the pic. I think that might improve the overall dust pick-up without even without the concern for clogging.
John
kd6vpe wrote:Here is what it looks like now. I used a scroll saw blade and hand cut out most of the grid leaving a cross section just for strength
Jim - How is that working for you? Any improvement?
