Any OK SS owners?
Hi Candy and Jim,
Glad you made it over here.
The rest haven't seen the machine picture you posted on LJs. You have a 500....I think. The 510 was an upgrade of table size and accessory table size.
Maybe someone here has some lathe accessories for sale. I'd start a thread and list the things you need. Hopefully, someone or several someones have a part or parts they'll sell.
Gene
If I understand the link Dusty provided, our green SS is indeed a 500.
Thanks for the link, Dusty. Gene, Good idea. Will start a post after we have a better idea of what all we need. In the mean time...
[ATTACH]25352[/ATTACH]
[ATTACH]25353[/ATTACH]
- photo 2.JPG (168.3 KiB) Viewed 2774 times
- photo 1.JPG (167.39 KiB) Viewed 2774 times
First, welcome to this forum.
Please overlook the second post to this thread. No harm intended.
Now, it be not easy to tell from the pix, but it appears to be an "A" headstock casting which is consistent with it being a 'Greenie' and most likely is a Gilmer drive belt version. I say 'likely' since it is possible to update. The belt cover looks like it may be a later version(only two retaining screws?) and maybe from a Goldie.
Glad to see the tables etc. in the second pix.
The motor pan appears to be a Goldie also but the pix may be showing rust rather than gold paint.
After cleaning it up, lubrication is advised. These beasts run forever when properly oiled(often) and maintained.
I figger more questions will come shortly so do not hesitate to express them.
Be careful, this machine can bite if one is careless with it. It does not have all the latest protect thee from thyself 'features'.
Bon Appétit!:)
P.S. It is a Mark 5 which predates the Mark V/500/505/510/520. There are other variations.
Bon Appétit!:)
- "Wild Bad Bob"
Correct on the color thing, whole different vocabulary here, and JPG has his own, but once you figure it out is everything you need to know. I dont know what they call the gray ones. I have been on some forums, and they had a sticky for theirs.
I did not welcome you here yet so Hi. You are in good hands here and allot of SS people near you in OK. Dont be intimidated by a SS, they are a very simplistic machine internally. Designed by a German engineer, with out the german over design practices, like in BMWs.
Descriptive terms
There are 3 different headstock casting versions.
"A"is the original sand cast headstock. It is rougher and thicker(heavier) and does not have an access hole on the reverse side.
"B" is the most common version. It is diecast and added the access hole on the back side(in the area of the two small holes on yours).
"C" is the current version and the access hole was enlarged and the power switch changed and moved.
There are three different power train versions.
The early Mark 5 had a Gilmer(cogged belt) drive and a 6 spline quill shaft and a 3/4 hp motor.
The later Mark 5 increased the motor to 1 1/8 hp and changed the drive to a poly-v belt and the quill shaft splines were increased.
The Mark V is essentially the same as a Mark 5, but has four different table configurations. 500,505,510,520.
The current Power Pro radically changed the drive train and includes a stronger DVR motor and simplified drive belts.
Color wise, there are the Mark 5 Greenies(like yours (sorta)). Color scheme silver and green hammertone.
Then came the early Goldies which were essentially the same as the Greenies. The Goldies are sometimes referred to as Brownies. Color scheme copper and light brown hammertone.
Next came the Goldie(Anniversary model(#1)) which included the 1 1/8 motor and poly-v drive.
Then came the gray wrinkle paint.
Then they went out of production.
When production resumed, they were again Mark 5s and gray. At some point in time the gray paint was changed to a different texture
(I call it splattered) and is current.
More re the Mark V sub models.
The 500 is the same as a Mark 5.
The 510 added the larger main table, floating tables with round rails, adjustable legs for additional support/set up ability.
The 505 was a stripped down 510 that included only the larger tables with round rails.
The 520 changed the round rails to the current boxey type(a notable improvement).
The rip fence design changed each time the tables changed.
The anniversary model(#2) has a different access hole cover.
The Mark 7 added tilt both direction as well as the Power Pro headstock.
Since even the earliest Greenies can be upgraded all the way up to a Mark 7 it is not always easy to discern what one has.
There have been less major design changes, but these are the major ones.
It is important to know just what one has if parts are needed(especially if procuring used parts on e-bay etc.). Some out of production parts are only obtained used.
I hope this does not overwhelm y'all and serves as an expanded 'glossary'.
Keep in mind there have been several corporate entities that have produced these models over the past 3 score +7 years. That so much is the same/compatible/upgradable is quite unique and one reason for the fierce loyalty of it's older owners. And another reason many of us have more than one.
FWIW there have been other models - Mark 1(only two known of), Mark 2 and Mark VII - as well as a few 'clones'.
- rjent
Candy and Jim!
I have been on the road for the last two days. I read the start of this thread in California and I just got home to New Mexico.
I have found this place to be a gold mine of information!
Your SS looks fabulous! You are going to get hooked like the rest of us!
Dick
Dick
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
1951 jigsaw X 2
- idcook
rjent wrote:Candy and Jim!
Dick
Welcome Jim & Candy!
That hooked rjent speaks of will begin almost as soon as you get into restoration of the machine. You’ll fall in love with how wonderfully it operates using brilliant simplicity of design.
After you get it all pretty, or maybe just up and running, one or both of you may find that you have to hold the other back from racing to buy every raggedy scrap of Shopsmith you lay eyes on.
Enjoy!
