Incra Box Joint
Re: Incra Box Joint
dusty wrote:OKAY. I am done debating this decision. I thank all of you who responded. I placed an order today for an Incra I-Box.
I think you will like it. :)
Re: Incra Box Joint
I have not yet assembled it but I received my I-Box from Incra today. As has always been the case with Incra, I am impressed. Starting with the package of parts one sees evidence of quality and caring. Everything is packed neatly and properly prepared for the hazards of shipping. The users guide is a work of art on heavy duty, glossy paper. I read through the instructions and am a bit confused about a couple things but that will most probably clear up when I actually do the assembly.
I think you are right, John. I believe I will like it - probably so much that I will discard my old box joint jig.
Re: Incra Box Joint
dusty wrote:I have not yet assembled it but I received my I-Box from Incra today. As has always been the case with Incra, I am impressed. Starting with the package of parts one sees evidence of quality and caring. Everything is packed neatly and properly prepared for the hazards of shipping. The users guide is a work of art on heavy duty, glossy paper. I read through the instructions and am a bit confused about a couple things but that will most probably clear up when I actually do the assembly.
I hope so. When you get it dialed in it is perfect. Dialing things in is what you do best. There is a bit of a learning curve but not much. Pay attention to the instructions and the video. I found them to be spot on. Once you get your head around what they are saying it makes sense.
I use the Forrest 1/4 and 3/8 inch blade set. There are no shims so they are dead on. If using a standard dado set your success may vary.
rjent
Re: Incra Box Joint
Post by rjent »
I am glad I started this thread. i just ordered one myself and it shipped yesterday. I am looking forward to using it. Thanks guys!
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
Re: Incra Box Joint
rjent wrote:I am glad I started this thread. i just ordered one myself and it shipped yesterday. I am looking forward to using it. Thanks guys!
I hope you are not disappointed. I certainly have not been.
Gene Howe
Re: Incra Box Joint
Post by Gene Howe »
Ditto, Dick. Have fun. Check out the hinge crafter next.
rjent
Re: Incra Box Joint
Post by rjent »
I was watching the video. That hinge crafter is slick! It is always something .... LOL
Dick
1951 jigsaw X 2
Re: Incra Box Joint
Putting the I-Box together and making it ready seems as though it should be a piece of cake. It probably is, if you read and follow the directions and do nothing else. Don't look at pictures. Not even those posted here on the forum. There are subtle differences.
For use with a Shopsmith (tilting table), should the I-Box be assembled per the left tilt or the right tilt instructions?
I choose to treat mine as though it was a left tilt. Hope that is what every one with a Shopsmith has done or I am the odd man out.
I have the red adjustment know on the left end of the I-Box when viewing it as thought I was working at the table saw. In this configuration I have the Miter Bar Assembly installed to the left of the cutout for the blade/bit.
The T portion of the Miter Bar is on the side nearest the operator.
Now I have it fully assembled and I believe I have followed all of the directions for use on a left tilt table saw. BUT mine does not match the picture on the top of the box. I have a mirror image of what is on the box.
Is this a difference that occurs if I switch to a router setup????
Re: Incra Box Joint
Sounds about right to me. You can check my thread on this here:
http://www.shopsmith.com/ss_forum/viewtopic.php?t=12807
rjent
Re: Incra Box Joint
Post by rjent »
dusty wrote:Putting the I-Box together and making it ready seems as though it should be a piece of cake. It probably is, if you read and follow the directions and do nothing else. Don't look at pictures. Not even those posted here on the forum. There are subtle differences.
Dusty, did you have the bolt head clearance problem that reible discussed in his thread, or have they fixed that ... Just wondering ...
Dick
1951 jigsaw X 2
