-------------------JPG wrote: Thu Mar 10, 2022 8:59 amRead that link with a salt shaker.Hobbyman2 wrote: Wed Mar 09, 2022 11:25 pm are you sure it is wired right for 110 ? If I recall there are wiring instruction inside some motors that will allow voltage conversions / speed changes , can you find a manual ? if so remove the electrical cover and check for alterations ?
a 3/4 hp motor should be more than enough to cut a pine 2x4 ? .
I would have to look but my 15 amp circular saw cant be too much more than that ?
So for a 2 HP motor it will be 1500 watts or 1.5 KW. An easy way to convert HP (horse power) to Watts is by multiplying by using 745.7W/HP as a conversion factor; so a 2HP motor produces 1,491.4W of power (1.4914kW).
How many watts does a 2 HP motors have? - Quorahttps://www.quora.com › How-many-watts-does-a-2-HP-...
UNDERSTANDING WATTAGE & AMPERAGE
https://midwestconstructionrentals.com/ ... d-amperage
I didnt look them over that well , What did you see ??
