$75 Shopsmith - let the fun begin...
wlhayesmfs
Post by wlhayesmfs »
IF you have a second SS this part I made worked when turning down some rusty tubes I have for some ER's
What do you think?
[ATTACH]5580[/ATTACH]
[ATTACH]5581[/ATTACH]
tube cradle 3.jpg (1.9 KiB) Viewed 1939 times
tube cradle 2.jpg (2.41 KiB) Viewed 1926 times
Bill :)
Broken Arrow OK
wlhayesmfs
Well guess I need to work on how to make the pictures bigger,
Sorry:eek:
Bill :)
Broken Arrow OK
wlhayesmfs wrote:IF you have a second SS this part I made worked when turning down some rusty tubes I have for some ER's
What do you think?
What did you use on the 'chuck' end?
wlhayesmfs
It is a standard 4 jaw chuck Will try and to post a bigger picture
[ATTACH]5583[/ATTACH]
tube cradle.jpg (6.11 KiB) Viewed 1921 times
Bill :)
Broken Arrow OK
wlhayesmfs
oK how do I get my pictures to be larger on the attachments? not sure what I am doing wrong. On the computer under pictures they are large and clean then when done as an attachment small and cloudy. Not had this problem be for when attaching.
Thanks
Bill :)
Broken Arrow OK
billmayo
Post by billmayo »
I have made a few of these using the softer caster wheels. The mounting holes in the tailstock are slots that I drilled and filed so the casters can be adjusted. The tail stock remains fully functional. I use a 3 internal jaw 4" metal lathe chuck with a 5/8" adapter to hold the tubes. Really does a beautiful job on the tubes as I can clean, polish and wax them. I also find bent tubes when mounting them in this setup. This tube was 100% rusty and not fully cleaned yet. About 5 minutes of work so far for this picture.
[ATTACH]5584[/ATTACH]
wlhayesmfs
Bill, great idea and even easier to build that what I tried. I had an extra tail stock and never thought of that. I guess that is why we all turn to you because at one time you have probably already done or tried it.
Thank for the picture. Now I know what I will make next
Bill :)
Broken Arrow OK
mickyd
Post by mickyd »
wlhayesmfs wrote:oK how do I get my pictures to be larger on the attachments? not sure what I am doing wrong. On the computer under pictures they are large and clean then when done as an attachment small and cloudy. Not had this problem be for when attaching.
Thanks
Bill,
Do you have any photo image editing software installed on your computer? That's where you'd resize your photos to make them appear larger.
Sunny San Diego
beeg
Post by beeg »
Here's a free one that I use.
http://www.irfanview.net/
rstl99
Attached all previous pictures within the posts!
Post by rstl99 »
Taking JPG's suggestion to heart, I have gone back and property inserted my pictures into the posts using the paperclip feature, for easier viewing. I'll attach any future pictures of my project using this method, in the future.
BTW, Irfanview is a very nice piece of picture manipulation software, it's the one I've been using for years, and it's FREE! :D
Cheers!
