Casters
keakap
Post by keakap »
First thing I noticed was this: insert the other end "just up to the end of the casting". (at the headrest end)
Wholly cow! When I first got a look at mine the bench tube was easily a 1/4" further in. And the Way tubes had a vast gap between the cap and the headrest.
Gadzooks, this is going to be interesting.
Yes I did see the link to the re-assembly "manual" and that's where I'm going next.
Thanks, btw.
keakap wrote:Isn't that vice versa? The Base casting has the "stop" rib that limits how deeply one may probe with the Bench Tube.
Methinks the limit at the Headrest end is determined by the Way Tubes.
You are absolutely correct. The built in stops are located in the Base and not in the Headrest.
At the Headrest end, if you run the Bench Tubes right up against the Extension Table Tubes it might be difficult (or impossible) to close the Tie Bar down far enough. The Tie Bar will be limited in travel by the Base. To fix that, loosen the Bench Tubes at the Headrest end and pull it back until the Tie Bar drops in place and then retighten the Bench Tubes.
keakap
Post by keakap »
dusty wrote:No, I have not yet installed the carriage on this set of tubes. My carriage and (new) headstock are in the process of being prepared for paint.
That's some lens you have on that camera. Makes the tubes look like they're about 22" long.
nuhobby
Post by nuhobby »
keakap wrote:That's some lens you have on that camera. Makes the tubes look like they're about 22" long.
Yes, Dusty has a neat camera, see also Post #12 here:
http://www.shopsmith.net/forums/showthr ... 025&page=2
Chris
That is a very good estimate (analysis) of those photos. Actually those tubes are two pieces of EMT that I use as tubes from time to time and they are 24" long.
keakap
Post by keakap »
dusty wrote:That is a very look estimate (analysis) of those photos. Actually those tubes are two pieces of EMT that I use as tubes from time to time and they are 24" long.
Dang! 2" off. I need to clean my monitor screen...
-er sumpthin
By the way, Dusty, the rehabilitation process is moving right along.
Everything was off. Everything was fighting everything else, as you suggested.
I got the base and bench tubes set, then the headrest end synchronized up using the ol' jiggle-n-torque method, and basically using the floor as 'base' reference. Now trying to figure out tube lengths.
Much progress. Much optimism.
