My first Mark V rebuild, heck my first Mark V
jayp413
Post by jayp413 »
[quote="JPG40504"]BTW If you have not yet removed the motor and pan from the headstock, do so. It gets a lot lighter and you can then 'see' inside the headstock a whole lot 'gooder'!]
Ahhh brilliant! Next time i get into it that will be the first step! :cool:
calstar
Post by calstar »
Hi Jay, thanks for the great pics. It is a lot easier to work on the headstock with the motor out, that's the first thing I did, easy to turn the headstock into any postilion with the motor gone. My V's disassembled, I need to send the speed dial to get a new steel gear put in for the toasted old one. Yours looks good. That is a poor design for the gear. After seeing mine if I take another one apart I'll send the speed dial off for a new steel gear regardless of it's condition, $17 and your good for as long as you own it. I'm going to replace the bearings since its opened up. You can buy almost any size bearing from Accurate Bearing(a big wholesaler that will sell you 1 or 2 at a time if you want at the best prices I've found), fast and great service, google them for more info. Thanks again for the help with the picture posting.
Brian
jayp413
Post by jayp413 »
calstar wrote:Hi Jay, thanks for the great pics. It is a lot easier to work on the headstock with the motor out, that's the first thing I did, easy to turn the headstock into any postilion with the motor gone. My V's disassembled, I need to send the speed dial to get a new steel gear put in for the toasted old one. Yours looks good. That is a poor design for the gear. After seeing mine if I take another one apart I'll send the speed dial off for a new steel gear regardless of it's condition, $17 and your good for as long as you own it. I'm going to replace the bearings since its opened up. You can buy almost any size bearing from Accurate Bearing(a big wholesaler that will sell you 1 or 2 at a time if you want at the best prices I've found), fast and great service, google them for more info. Thanks again for the help with the picture posting.
Brian
Thanks for the info Brian! It's been great posting up the pictures because there are alot of people who can help spot things I may miss as a newbie.
I agree with you on changing the bearings out while it's open. Might as well get the headstock in great running condtion to prevent a future tear down for maintinance! I'll check out Accurate Bearing and possibly get my dial built as well. Heck for $17 it's a no brainer! :cool:
jayp413
Post by jayp413 »
Ok, so I removed the motor housing for ease of work and it was the best move I could have made. Simple but it eluded me :p . I tried to use an "easy out" to remove the allen that was stripped above the quill feed housing and had no luck. I ended drilling out the allen screw dead center hoping not to destroy the existing threads. I did go a hair to deep but it was successful. the issue I am running into is the conical washer on the shaft is stopping my removal of the housing. there is a step built into the shaft that is not allowing for me to slide it past the conical washer. Is this a normal set up? There is no notch in the washer to allow it to pass. Any ideas? Comments?
peterm
Post by peterm »
I believe the obstruction is a Woodruff key, part no 42 in this diagram:
http://www.shopsmith.com/ownersite/part ... xpview.htm
and is removable from its slot.
Peter
BigSky
Post by BigSky »
Check this thread. Some excellent images of what you are attempting.
MarkFive510
judaspre1982
Post by judaspre1982 »
jayp413 wrote: Image
IIRC The spherical washer will clear the woodruff key, but if the key is cocked, the inside end may stick up too high. First try tapping the inside end down into the slot. If that does not work, totally remove the woodruff key. You may need to pull hard on one end to get it to move(it is a tight fit). Try to not scar it.
jayp413
Post by jayp413 »
Thanks everyone for helping out! i'm going out right now to see how it goes. :cool:
jayp413
Post by jayp413 »
Well I tried to give it a tap on the high side and it didn't budge. I gave it a stronger "nudge" and it mushroomed on the end :( Looks like I'll have to replace it. It's abit late to make that much noise so I'll tackle it tommorow.
http://www.shopsmith.com/ownersite/p...blyexpview.htm
80 cents to replace. I can deal with that! :cool:
