This is my first ER and just cleaning it up a bit. The upper belt was wore and the lower was an old red link belt. I have 2 belts that match up with the help of some ER folks, but I need pointers I guess on the best method of install.
I have the speed changer and I know this is supposed to be a breeze to switch between set ups. I've looked through the original manual and the original speed changer sheet, I don't see any best practices here.
Please advise.
On some days I feel my IQ is well over 30, not today.
ER Belt Change
ER Belt Change
R Hart
- timsturnings
I just bought a speedchanger for my ER and I raise the motor to loosen the tension on the belts and just unscrew the retaining nut on the end of the speedchanger and slide off the pulley and belts from the speedchanger. It was pretty easy. I read it somewhere on the instructions for the accessory.
Tim.
Tim.
Seven days without turning makes one weak.
1952 Shopsmith 10er(restored)with Speedchanger,1952 Craftsman 10" table saw,Jet 1014 lathe(VS),HF VS 95607 Lathe,Craftsman Drill Press,55 Gal. Tornado Dust Collection System,Shop Wide Overhead Vac piping,WC slow-speed grinder,Wolverine sharp. system,Grizzly GO580 14" Bandsaw,Rikon Disk/Belt sander,HF Pressure Pot, JB 7 CFM Vac pump,TurnTex Stabilizing Chamber. (My 16' X 20' shop is full to the gills)
- timsturnings
You shouldn't have to remove the headstock pulley or the motor pulley. When the belts are loose, by raising the motor, just slide off the belts as you are removing the speedchanger pulleys. It seems to be a very easy belt change, on my ER anyway.
