Planer with power station?
saminmn
Ignore this duplicate thread of Planer with power station
Post by saminmn »
Sorry, this a duplicate of a thread. Do not reply (except if you know how to properly remove this erent thread)
Sam in Northfield, MN
A day without beer......could have been better :p :D :p
Mark V 500 - S/N 100990, Mark V 510 - S/N missing, SS Band Saw, SS 6" Belt Sander, SS 4" Jointer, SS Scroll Saw, SS DC3300
SDSSmith
Post by SDSSmith »
saminmn wrote:I am thinking of getting a joiner mounted on a power station. I was looking as SS web site and noted that thicknesser is not a power station option. I had been attracted to the add because it had a power station and an earlier thread had indicated the planer was heavy to be moving around so I had thought a semi permanent home would be good if I ever got a planer. So my question is is there a real incompatibility? Or is it just a slower operation with the lower hp and rpm?
The Power Station is not designed to drive the thickness planer.
Rob in San Diego
saminmn wrote:Sorry, this a duplicate of a thread. Do not reply (except if you know how to properly remove this erent thread)
It will work but marginally. The maximum speed from the Power Station will give you a jointer speed of 4375rpm.
saminmn
Post by saminmn »
Sorry to have created the duplicate thread issue. So, will lower speed make poorer quality surface
SDSSmith
Post by SDSSmith »
dusty wrote:It will work but marginally. The maximum speed from the Power Station will give you a jointer speed of 4375rpm.
:confused:
It won't work marginally unless you modify the power station. It is not designed to have the planer mount on it.:cool:
Rob in San Diego
saminmn wrote:Sorry to have created the duplicate thread issue. So, will lower speed make poorer quality surface
Yes, the lower speed would reduce the quality of count. But there may be a more important (more limiting issue).
SDSSmith: Please explain. I have both a Crafters Station and a Power Station and I can mount my jointer on either of them. What am I missing???
dusty wrote:Yes, the lower speed would reduce the quality of count. But there may be a more important (more limiting issue).
We be discussing a planer!!!!!:)
