What are these?
dmsokol
What are these?
Post by dmsokol »
Hi.
I just got a Mark V, Model 500 from a friend and several attachments. There are a few things that I don't know what they are.
Can you help?
Two photos are attached.
Thanks.
Dennis
what's this.JPG (57.31 KiB) Viewed 2246 times
what are these.JPG (60.52 KiB) Viewed 2244 times
judaspre1982
Post by judaspre1982 »
judaspre1982
The 2nd pic is of rub collars. They go on a shaper arbor to prevent too big of a bite. The workpiece will glide along a fence and rub on the collar. The collar(s) provide the same purpose as bearings on router bits.
Shaper must be used with a split fence like this one. http://www.shopsmith.com/ownersite/catalog/ms_shaperdrumsanderfence.htm
EDIT!!! AFTER READING DAVE'S POST (JUDASPRE1982) (NEXT POST) I NOW NOTICE THE THICKNESS -- THEY ARE NOT RUB COLLARS. DON'T KNOW WHAT THEY ARE FOR.
judaspre1982
Nice catch,Dave!:) I didn't notice the thickness! Looked too fast.:(
bffulgham
Post by bffulgham »
judaspre1982 wrote:Now I'm not sure what is in the 2nd pic.
Rub collars are thicker than the 3 smaller items.
http://www.shopsmith.com/ownersite/cata ... rarbor.htm
I do see a difference in some of the diameters.
The small round face washer is unfamiliar to me now that I look closer.
Anyone else?:confused: :D
Dave
I agree that the 3 larger washers are from the molder/dado arbor.
The smaller washer in the bottom left looks like it may have straight 'sides' in the center. I've seen these used on circular saws that have a flat on both sides of the shaft to capture the washer and prevent torque from unscrewing the bolt holding the blade. Don't think it's a SS pieces/part.
Bud F.
bffulgham wrote:I agree that the 3 larger washers are from the molder/dado arbor.
You nailed it! A double d washer(non-ss). Dado arbor spacers(3).
