Shopsmith 2" Casters
Does anyone out there have the newer 2" casters. What Shopsmith is offering as a replacement caster appears to be a small version of the new 3" caster. This wheel assembly appears to be a bit heftier than the originals.
This picture shows the wheel assembly that I currently have and it also shows the original wheel along with the new wheel type that I put on my Pro Planer (heavier SPT).
[ATTACH]17726[/ATTACH]
New Wheels 003 (Custom).JPG (70.7 KiB) Viewed 1492 times
claimdude
Post by claimdude »
dusty wrote:Does anyone out there have the newer 2" casters. What Shopsmith is offering as a replacement caster appears to be a small version of the new 3" caster. This wheel assembly appears to be a bit heftier than the originals.
Dusty,
I have the newer gray 2" SS wheels on my MK V PowerPro and my Power Stand. Wheels roll way better than the old black plastics ones.
Jack
sunset22
Post by sunset22 »
I bought some 2" from menards that work well.
Sunset22
trainguytom
Menard's casters
Post by trainguytom »
I also have Menard's casters on 2 of my machines & they're a great improvement. About $4 each. Ball bearing swivel. I mentioned them in an earlier post that took on a life of it's own & analyzed the crap out of a simple, cheap, great, readily available concept. The bottom line is: they're all of the above.
My dad's 1951 10er, 2 more 10er's, same vintage, a Goldie MK5, a 510 shortie with 34inch tubes, bandsaw, jointer, jigsaw, belt sander, a ton of small SS goodies and still looking...you just can't have enough Shopsmith stuff
trainguytom wrote:I also have Menard's casters on 2 of my machines & they're a great improvement. About $4 each. Ball bearing swivel. I mentioned them in an earlier post that took on a life of it's own & analyzed the crap out of a simple, cheap, great, readily available concept. The bottom line is: they're all of the above.
Analysis(lengthy) due to a combination of past circumstances and insufficient info to determine if same circumstances existed.
Details are what nibble on yer derriere!;)
