I purchased my first ShopSmith in 1979 and I believe it came with plans for a wood gumball machine made from a 2x4 block 3 1/2 X 3 1/2 on a 1x6x5" base. It had a hole in the top where you could place a mason jar and a dowel coming out of the front of the 2x4 with a porcelain knob attached. Between the 2x4 & 1x6 there is a dowel pin & the dowel with the porcelain knob has a routed track. I need the measurements on the pin and routed track. I have one base left and have photo attached but do not want to tear up to get measurements.
Is it possible someone has these old plans?
Wood Gumball machine
- Gumball.jpg (50.85 KiB) Viewed 2757 times
Is this the Gumball Machine you are looking for?
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
- terrydowning
Awesome, thanks!!
Not sure it's what the OP as asking for, but that works for me!
Thanks Joe.
Thanks Joe.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
I think this is what you want. It's from the Sept/Oct 1980 issue of Hands On!.
[ATTACH]18471[/ATTACH]
gumball001.pdf- (723.31 KiB) Downloaded 1206 times
Here's one from Hand's On Magazine Sept/Oct 2000. I'd post a pic, but I can't right click with the iPad.
http://www.shopsmithhandson.com/archive ... roject.htm
