Double tilt upgrade
ryanbp01
Double tilt upgrade
Post by ryanbp01 »
I have the double tilt upgrade and was reading though the instructions. Is there another way of accomplishing the upgrade without turning the unit upside down? Since there's only one of me, I'm afraid of doing damage to the headstock.
BPR
With an extension on the(both?) end and the main table set to the same height, the headstock will never come under stress.
The secret is to roll it over slowly(gently) with no 'jarring'.
If you set it on saw horses wide enough, the tubes will support it entirely in both positions and in between and the tables can be removed to decrease weight.
forrestb
block and tackle came in handy
Post by forrestb »
I had long ago install a medium-sized block and tackle to allow me to lift solid-core doors onto my working frame. I have it bolted onto a joist in my workshop (aka SWMBO garage space).
It really came in handy when it came time to install my double-lift since all my friends are 'seasoned' and have bad-to-worse backs (like me). It allowed me to control the roll-over slowly as JPG advised without needing any help. Just be sure that you understand where the COG is so that it doesn't jump at you when tilting.
Forrest
Forrest
Huntington Beach, CA
MikeG
Post by MikeG »
Send me an PM if you need an extra hand. I'll send you my phone number and we can setup a time that I can come over and help you. You know I'm not that far away.
fjimp
Post by fjimp »
MikeG wrote:Send me an PM if you need an extra hand. I'll send you my phone number and we can setup a time that I can come over and help you. You know I'm not that far away.
Now there is a kind offer worth taking advantage of. Truly turning the tool upside down will net the best results. Having an extra pair of hands is both fun and safe. Good luck both of mine have been upgraded to Mark 7 and the results are well worth the effort. Jim
F. Jim Parks
Lakewood, Colorado:)
cincinnati
Post by cincinnati »
I would just remove the headstock first. Very easy to do.
"Prove to all the world Metal rules the land"
-Judas Priest, Heavy Duty.
